How to get attributes using GPS coordinate from webmap
1283
9
10-30-2023 06:32 PM
Labels (2)
AENA
Hi, currently i'm working with webmap and i want to find an attributes in the webmap by using GPS coordinate
output expected  :
Location: Jalan Jabatan Perhutanan, Keningau, Bahagian Keningau, 89000, Sabah, MYS
KODDUN: N.04, NAMADUN: TANJONG KAPOR
output that i obtaint :
it print out all the attributes instead of the one that match with coordinate.
KODDUN: N.03, NAMADUN: PITAS
KODDUN: N.05, NAMADUN: MATUNGGONG
KODDUN: N.06, NAMADUN: BANDAU
KODDUN: N.09, NAMADUN: TEMPASUK
my code :
from arcgis.gis import GIS
import arcgis
from arcgis.geometry import Geometry
from arcgis.geocoding import reverse_geocode
gis = GIS()
webmap_item_id = "0c7d9a944a5a476694a2f998d53e3e1e"
webmap_item = gis.content.get(webmap_item_id)
webmap_data = webmap_item.get_data()
longitude = 116.157966
latitude = 5.341622
given_coord = {'x': longitude, 'y': latitude, "spatialReference": {"wkid": 4326}}
point_geom = Geometry(given_coord)
location_details = reverse_geocode([longitude, latitude])
place_name = location_details.get('address', {}).get('LongLabel', 'Unknown Location')
print(f"Location: {place_name}")
if 'operationalLayers' in webmap_data:
for layer in webmap_data['operationalLayers']:
if 'featureCollection' in layer:
for layer_collection in layer['featureCollection']['layers']:
for feature in layer_collection['featureSet']['features']:
attributes = feature['attributes']
geometry = feature['geometry']
koddun = attributes.get("KODDUN")
namadun = attributes.get("NAMADUN")
parlimen = attributes.get("PARLIMEN")
# Fetch GPS coordinates
if 'x' in geometry and 'y' in geometry:
longitude = geometry['x']
latitude = geometry['y']
print(f"KODDUN: {koddun}, NAMADUN: {namadun}, PARLIMEN: {parlimen}")
else:
print(f"KODDUN: {koddun}, NAMADUN: {namadun}")
hope someone can help me because this is my first time using API
EarlMedina
Hello,
If I understand what you are trying to do correctly, you are quite close and just need to add a geometry function to figure out if the input point is within the geometry. You may use Geometry (which will parse the type for you), but I will use Polygon and Point so it is more explicit what is going on. I'm not sure what the intention was with the else statement, so you may need to adjust further:
import arcgis
from arcgis.geometry import Point, Polygon
gis = GIS()
latitude = 5.341622
given_coord = {"x": longitude, "y": latitude, "spatialReference": {"wkid": 4326}}
point_geom = Point(given_coord)
place_name = location_details.get("address", {}).get("LongLabel", "Unknown Location")
                    if "rings" in geometry:
                        poly_geom = Polygon(geometry)
                        if point_geom.within(poly_geom):
                    else:
AENA
Hello, thankyou for the replied.
may I know if you get the expected output?
I've tried to run the code, but seems like it's not working correctly because I only get the location name but not the attributes(KODDUN, NAMADUN).
EarlMedina
Hey, I get this:
KODDUN: N.40, NAMADUN: BINGKOR, PARLIMEN: KENINGAU
AENA
Hai, I'm sorry if I ask you a lot of question because this is my first time using python API.
I've tried to run the code that you share, but I only get the location name. may I know why?
AENA
@EarlMedina
@VinceAngelo
can you help me with this one.
EarlMedina
The only thing that comes to mind is you may be on a differen version of the API? I re-ran the code and came out with the exact same output.
AENA
may i know what version and platform to run the code that you use ?
AENA
btw, I'm using google colaboratory to run the code. @EarlMedina
EarlMedina
2.1.0 is the version, I believe.
