How to find dependencies in Portal for ArcGIS using ArcGIS API for Python?
4816
5
12-14-2022 07:19 AM
Labels (3)
ErnestoCarreras2
Hello, I am trying to figure out item dependencies in my ArcGIS online account to perform some cleanup afterwards. When I execute the script, it is not printing the dependency information the way it should be. I got the script from Esri’s technical Support website: https://support.esri.com/en/technical-article/000021183
Any assistance/guidance will be appreciated.
The following is an example of what I am getting from the script:
Item:        Ravenswood Parking Lot                    id d3x20842a3a349e19cd438x86c8a84fx is dependent on these items:      {'total': 0, 'start': 1, 'num': 0, 'nextStart': -1, 'list': []}
Tags (3)
RhettZufelt
MVP Notable Contributor
Did you paste in the item ID when prompted, then hit enter and continue running the code?
R_
RhettZufelt
I have had success using the notebook here.
R_
ErnestoCarreras2
Hello and thank for the quick response. For some reason, it has not worked for me... it keeps spinning as it is running something in the background but nothing gets returned.
RhettZufelt
R_
ZakBaron
Thank you so much for that clarification. I was trying a lot of variations to get the notebook to work, but that did the trick. This is a great tool to have in my kit!
DISIG
hello,
I use this script for deep search using rest url as starting point.
