How to do data augmentation for deep learning model
3884
11
04-15-2021 07:47 PM
lienpham83
New Contributor III
I got training data for my deep learning model by using export training data for deep learning tool in Arcgis Pro. I would like to do data augmentation on this training data. So, my code is
data=arcgis.learn.prepare_data(r'G:\data_training',
class_mapping={0: 'tree'}, chip_size=640, val_split_pct=0.1, batch_size=2,transforms=True,resize_to=800).
When I run the code, it has error:
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\learn\_data.py, in prepare_data:
Line 1570:  data = (data.transform(transforms, **kwargs_transforms)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\fastai\data_block.py, in transform:
Line 504:   assert is_listy(tfms) and len(tfms) == 2, "Please pass a list of two lists of transforms (train and valid)."
AssertionError: Please pass a list of two lists of transforms (train and valid)
 Could you please suggest how I can fix this error? Thank you for your help
Tim_McGinnes
Occasional Contributor III
Esri use a default set of transforms, but I have not been able to find them documented anywhere. Stated on this page :
By default, prepare_data() uses a default set of transforms for data augmentation that work well for satellite imagery. These transforms randomly rotate, scale and flip the images so the model sees a different image each time. Alternatively, users can compose their own transforms using fast.ai transforms for the specific data augmentations they wish to perform.
You will have to dig into the code to find out what is being done for each model type. The prepare_data function is in C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\learn\_data.py
As an example, for MaskRCNN, this is in the code:
    if dataset_type == 'RCNN_Masks':
        if transforms is None:
            ranges = (0, 1)
            if _image_space_used == _map_space:
                train_tfms = [
                    crop(size=chip_size, p=1., row_pct=ranges, col_pct=ranges),
                    dihedral_affine(),
                    brightness(change=(0.4, 0.6)),
                    contrast(scale=(1.0, 1.5)),
                    rand_zoom(scale=(1.0, 1.2))
            else:
                train_tfms = [
            val_tfms = [crop(size=chip_size, p=1., row_pct=0.5, col_pct=0.5)]
            tfms = (train_tfms, val_tfms)
So, it clear from the code that you need a list of training transforms and a list of validation transforms. Then they are combined into a tuple and that is what you put in the prepare_data transforms parameter.
Here is the documentation for the fastai transforms: https://fastai1.fast.ai/vision.transform.html
Something like this should get you started (the get_transforms function is an easy way, but you can individually create your own transforms also):
from fastai.vision.transform import get_transforms
tfms=get_transforms(do_flip=True, flip_vert=True, max_rotate=None, max_zoom=1, max_lighting=None, max_warp=None, p_affine=None, p_lighting=None, xtra_tfms=None)
tfms=(tfms1,tfms2)
data=arcgis.learn.prepare_data(r'G:\data_training', class_mapping={0: 'tree'}, chip_size=640, val_split_pct=0.1, batch_size=2,transforms=tfms,resize_to=800)
I haven't really played around with transforms much yet, so please let me know how you go.
DanPatterson
MVP Esteemed Contributor
arcgis.learn module — arcgis 1.8.5 documentation
arcgis.learn.prepare_data(path, class_mapping=None, chip_size=224, val_split_pct=0.1, batch_size=64, transforms=None, collate_fn=<function _bb_pad_collate>, seed=42, dataset_type=None, resize_to=None, working_dir=None, **kwargs)
The first entry is supposed to be a data path, you passed it a string ( 'data_training' ).  If data_training is supposed to be the path, dump the single quotes
... sort of retired...
lienpham83
New Contributor III
My first entry is a path.
DanPatterson
see the single quotes around 'data_training'
that makes this a string
drop the single quotes like so..... data_training ...
If that is indeed the path
lienpham83
New Contributor III
my code :
DanPatterson
Ahhh I see from your revision history you fixed this arcgis.learn.prepare_data('data_training',
by adding the raw encoded G:\ to it.  Good.
At least that was ruled out
Optional tuple. Fast.ai transforms for data augmentation of training and validation datasets respectively (We have set good defaults which work for satellite imagery well). If transforms is set to False no transformation will take place and chip_size parameter will also not take effect. If the dataset_type is ‘PointCloud’, use Transform3d class from arcgis.learn.
For transforms it says it is looking for a tuple.... you entered ... True
lienpham83
New Contributor III
Although I used the code  below, it still has the same error as in the originial post
DanPatterson
see my post... you missed the whole transforms thing
lienpham83
New Contributor III
tfms:Optional[Tuple[TfmList,TfmList]]. What should be TFmList? Is this the folders contain the train images and validation images?  How can I get TfmList?
Tim_McGinnes
            ranges = (0, 1)
                train_tfms = [
                    dihedral_affine(),
            else:
                train_tfms = [
tfms=(tfms1,tfms2)
