How do I get the data from HostedFeatureLayer for today's date using python from ArcGIS Online
3350
8
12-06-2022 05:00 PM
ChallagundlaSindhuraITS
Curently, I am pulling all the data from the featurelayerid using the below script:
feature_layer_id = ' ' Inspform = gis.content.get(feature_layer_id) insp=Inspform.layers[0].query().sdf insp.to_sql('testtable',con=engine,schema=None,if_exists='replace',index=False,index_label=None,dtype=None,method=None)
The featurelayer has two fields with create date and edit date. would like to pull data where createdate or edit date is equal to sysdate.
How can i achieve this? I am new to python and Arcgis
I browsed some sample notebooks, but no luck
Tags (1)
JamesCrandall
It's expecting a formatted date.  I do something similar to setup where clause for querying the last 24 hours on a feature layer.
from datetime import datetime, timedelta
last_24hour_date_time = datetime.now() - timedelta(hours = 24)
timestamp = last_24hour_date_time.strftime('%Y-%m-%d %H:%M:%S')
whereClause = "CreationDate>= '{}'".format(timestamp)
JamesCrandall
You probably just want feature_layer.query().  Take a look at the docs
Thank You, I tried something like this, I dont want to hard code the date. It should be sysdate.
insp=Inspform.layers[0].query(where =" CreationDate > [datetime(2022, 10, 7)]").sdf ; I am trying to figure out the correct syntax
JamesCrandall
Thank You James, The CreationDate format is
2022-10-07 17:46:00.158999808
Tried below statements , but no luck. Please Advise.
inspd=Inspform.layers[0].query(where = "CreationDate>= '{}'".format(timestamp)).sdf
inspd=Inspform.layers[0].query(where = "CreationDate>= '{}'".format(last_24hour_date_time)).sdf
Tags (1)
JamesCrandall
timestamp = last_24hour_date_time.strftime('%Y-%m-%d %H:%M:%S.%f')
This statement also didn't work for me.
print(timestamp)
2022-12-07 14:44:34.257940
Do you think its because the milli seconds in the creationdate has 9 digits and the timestamp is showing 7 digits and its not getting compared ?
JamesCrandall
That's why I added the "%f" in the strftime
It's hard to say what's the issue.  I don't really undersrtand what the .sdf is about?  Likely issue is something other than datetime formats.
Do this: go to the query task to your feature service and fill in the WHERE input parameter with what you think is correct.  If it works that's the formatting of your WHERE statement in your python script.
Did a workaround other than where clause, Below script worked:
last_24hour_date_time = datetime.now() - timedelta(hours = 1200)
#print (timestamp) #2022-10-19 18:41:09
filterinsp = insp[insp['CreationDate'] >= timestamp] ### this worked to get all 24 hours data
filterinsp
Thanks for your help!!
