Geoprocessing Service - Field Parameter Not Supported
646
06-19-2020 10:44 AM
LanceKirby2
Occasional Contributor II
I see in the ArcGIS Pro documentation here: Input and output parameters for geoprocessing services—ArcGIS Pro | Documentation that the field parameter should be supported. I am running ArcGIS Pro 2.5 and ArcGIS Enterprise 1.7 so I should meet all requirements; however, after publishing the GP service I receive the message below when setting up the service within the Geoprocessing widget. Any ideas?
DavidPike
MVP Frequent Contributor
Can you show your tool parameters before publishing?
LanceKirby2
Sure.
In my script I am using GetParameterAsText
    featureLayer = arcpy.GetParameterAsText(0)
    fieldName = arcpy.GetParameterAsText(1
    outPutName = arcpy.GetParameterAsText(2
DavidPike
Hmmm, perhaps set the first 2 parameters as arcpy.GetParameter(0) and  (1).
I'd take a stab at the dependency not being set as no object is input, however this is just a hypothesis.
