Export training data for deep learning
3516
14
11-05-2019 03:00 AM
MattiasTivlin
Hi all!
I'm trying to learn about python and deep learning. I have tried to follow the sample notebooks and watch the training courses but now i'm stucked.
I have done some training samples in Arcgis Pro with the training samples manager and saved it as a shapefile.
Then i export the samples with GP-tool "Export Training Data For Deep Learning" with KITTI Labels as Meta Data Format.
In jupyter notebook i write this to load the samples
from arcgis.learn import prepare_data
data = prepare_data('Path to my samples')
data.show_batch
The error i get
~\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone4\lib\site-packages\arcgis\learn\_data.py in prepare_data(path, class_mapping, chip_size, val_split_pct, batch_size, transforms, collate_fn, seed, dataset_type, resize_to, **kwargs)
572 return ner_prepare_data(dataset_type=dataset_type, path=path, class_mapping=class_mapping, val_split_pct=val_split_pct)
573 else:
--> 574 raise NotImplementedError('Unknown dataset_type="{}".'.format(dataset_type))
575
576 if dataset_type == 'RCNN_Masks':
NotImplementedError: Unknown dataset_type="KITTI_rectangles".
What am i doing wrong?
Regards Mattias
by Anonymous User
Not applicable
This is helpful, but I am still wondering why the KTTI Labels export is not working - could you elaborate on why the PASCAL method works, but KTTI labels does not? Thanks!
Wimalavan_Iersel
I am also curious about this issue with the KITTI labels. I have the same error as Mattias, but I can't switch to PASCAL since I want to use the training data for pixel classification. Any ideas? My KITTI labels already have points, so that can't fix it either... Thanks!
by Anonymous User
Not applicable
Hi Wimala,
If you want to do pixel classification you can use the format 'Classified Tiles'.
Sandeep
AlexaVerónicaGarcíaBarrantes
Hi Javier
specifically where do I replace all commas to points? I went fo the folder created after exporting the training data and all the files look like in the picture. I don't see any points or commas, should they be created differently?
Hi Javier
I replied to your thread before but seems like it didn't upload
Specifically, where do I replace the commas to points, after creating the image chips I went to the Label folder and they all look like in the picture. Are they supposed to be in a different format?
