I have a script, that reads a .csv, does some calculations and outputs some tables and some feature classes. Then I want to share these results with arcgis online. If I run the script as Jupyter Notebook, or as a script in a toolbox inside ArcGIS Pro, everything works like a charm. However I want it to run scheduled, so I run via D:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\pythonw.exe path\myscript.py. Here however the .sd files created by arcpy.server.StageService() behave differently, and I dont get all the tables and feature layers. The .sddrafts look almost the same, only differences seem to be some IDs. There is also a noteable size difference between the two .sd files.
The code I use for this part. Somebody has an idea what I could do differently?
Tested it with ArcGIS Pro 2.9 and 2.92
pw = parser.get('cred','pw')logging.debug("sd-Draft erstellen")send_message("Log","Progess","sd-Draft erstellen")# Set output file namesoutdir = workspaceservice = "MobilfunkstandorteTEST4"sddraft_filename = service + ".sddraft"sddraft_output_filename = os.path.join(outdir, sddraft_filename)# Reference map to publish#smRes = aprx.listMaps("ResultMap")[0]try:assert len(mRes.listLayers("Antennen")) == 1assert len(mRes.listTables("BundeslandOut")) == 1assert len(mRes.listTables("GemeindeOut")) == 1assert len(mRes.listTables("LandkreisOut")) == 1assert len(mRes.listTables("Filter")) == 1except AssertionError:logging.error("Assertion Error Resultmap")arcpy.AddError("Assertion Error Resultmap")sendMail("Assertion Error Resultmap")sys.exit()antennen_layer = mRes.listLayers("Antennen")[0]landkreise_layer = mRes.listLayers("Landkreise")[0]gemeinde_layer = mRes.listLayers("Gemeinde")[0]bundeslaender_layer = mRes.listLayers("Bundeslaender")[0]filter_table = mRes.listTables("Filter")[0]bundesland_table = mRes.listTables("BundeslandOut")[0]gemeinde_table = mRes.listTables("GemeindeOut")[0]landkreis_table = mRes.listTables("LandkreisOut")[0]elements_to_upload = [antennen_layer, landkreise_layer, gemeinde_layer, bundeslaender_layer,bundesland_table, gemeinde_table, landkreis_table, filter_table]# Create FeatureSharingDraft and set service propertiessharing_draft = mRes.getWebLayerSharingDraft("HOSTING_SERVER", "FEATURE", service, elements_to_upload)sharing_draft.summary = "My SummaryTEST"sharing_draft.tags = "My TagsTEST"sharing_draft.description = "My Description"sharing_draft.credits = "My Credits"sharing_draft.useLimitations = "My Use Limitations"sharing_draft.overwriteExistingService = True# Create Service Definition Draft filesharing_draft.exportToSDDraft(sddraft_output_filename)logging.debug("Creating Stage Service...")send_message("Log","Progess","Erzeuge Stage Service")# Stage Servicesd_filename = service + ".sd"sd_output_filename = os.path.join(outdir, sd_filename)# arcpy.server.StageService(sddraft_output_filename, sd_output_filename)try:retval = arcpy.server.StageService(sddraft_output_filename, sd_output_filename, 102)warnings = arcpy.GetMessages(1)print(warnings)except Exception as stage_exception:print("Sddraft not staged. Analyzer errors encountered - {}".format(str(stage_exception)))except Exception:e = sys.exc_info()[1]logging.error("sd-Draft erstellen:" + str(e))arcpy.AddError("sd-Draft erstellen:"+ str(e))#clearWorkspace()sendMail(str(e))sys.exit()try:logging.debug("Feature Service aktualisieren")send_message("Log","Progess","Feature Service aktualisieren")sd_fs_name = "HOSTED_FEATURE_SERVICE_NAME"user = "user"gis = GIS(portal, user, pw)shrOrg = TrueshrEveryone = FalseshrGroups = "Mobilfunkstandorte_Version2"logging.debug("Search for original SD on portal…")send_message("Log", "Progess","Suche original SD auf Portal")sdItem = gis.content.search("MobilfunkstandorteTEST4".format(sd_fs_name, user), item_type="Service Definition")[0]logging.debug("Found SD: {}, ID: {} Uploading and overwriting…".format(sdItem.title, sdItem.id))send_message("Log","Progess","Found SD: {}, ID: {} Uploading and overwriting…".format(sdItem.title, sdItem.id))sdItem.update(data=sd_output_filename)logging.debug("Overwriting existing feature service…")send_message("Log","Progess","Ueberschreibe existierenden Feature Service")fs = sdItem.publish(overwrite=True)if shrOrg or shrEveryone or shrGroups:logging.debug("Setting sharing options…")send_message("Log","Progess","Setze Teilungsoptionen")fs.share(org=shrOrg, everyone=shrEveryone, groups=shrGroups)logging.debug("Finished updating: {} – ID: {}".format(fs.title, fs.id))send_message("Log","Progess","Finished updating: {} – ID: {}".format(fs.title, fs.id))
