Deep learning - invalid argument 0: Sizes of tensors must match except in dimension 0
5112
5
11-29-2019 08:16 AM
VHolubec
Dear all,
I have issue with deep learning tools. I exported 12 000 training chips from Esri Imagery basemap to TIFF - see settings.png
The TIFFs looks fine as well as the labels file.
On calling data = prepare_data(data_path, class_mapping={1:'Pool'}, batch_size=64) I am getting error - UserWarning: It's not possible to collate samples of your dataset together in a batch.
warn(message)
For data.show_batch() -  now I am getting result - RuntimeError: invalid argument 0: Sizes of tensors must match except in dimension 0. Got 19 and 10 in dimension 3 at ..\aten\src\TH/generic/THTensor.cpp:711
I am not sure what does it mean? Does the Export training data tool corrupt some chips? Is there a way how to find out which chips are corrupted? Or how to fix it?
The chips were created in PRO by Export training data tool, so these could be fine.
Thank you for any idea.
Vladimir
Vladimir
by Anonymous User
Not applicable
Try to export the training data with chip size > 224 and choose jpg or png as your Image format. Also the cell size is very less, i do not know what kind of objects you are try to detect.
VHolubec
Dear Sandeep Kumar,
I am learning a model for pools. When I set bigger chip size, I am not able to get to detail like the attached one.
chip1
- the size is 200 to 200 pixels and cell size 0.045 (because the map is in WebMercator, I believe it´s in meters - am I right? ) - and the real size of the area is around 10x meters.
If I set the chip to 256x256 and pixel size to 0.2, I don´t think the resul is usable - see chip2
So I don´t know, if there is any other way, how to set the export of training chips more proper way?
The error I mentioned in the initial post - have you seen this? It seems for me some issue with the chips themselves. - RuntimeError: invalid argument 0: Sizes of tensors must match except in dimension 0. pls help - PyTo...
but I have no idea, how to identified the bad chips.
Thank you for any ideas.
Regards,
Vladimir
Vladimir
by Anonymous User
Not applicable
You can try a bigger chip size like 256px and for pools i would suggest a cell size of around 50cm (.5 in webmercetor) so that the model can learn the surrounding context too.
VHolubec
Dear Sandeep Kumar, with this settings it works. The problem is, that it seems to me so coarse (in comparision to previous settings) - see chip256-50cm
and the batch looks like this - no so ideal - no on every chips the pools is highlighted.batch
Please could you explain, why the ptevious settings did not work? Is there any limit to chip size and number of chips, which Python API could handle?
Thank you,
Vladimir
Vladimir
by Anonymous User
Not applicable
There is no limit on the chip number, but with a greater chip size you would require more memory to handle it. the show batch looks reasonable to me, to get a little bit zoomed in chips you can try reducing the cell size to 0.3 or 0.4.
