arcgis.learn.prepare_data module error while trying to training the data using samples
867
02-02-2020 07:01 PM
Md_TauhidulIslam
New Contributor II
I am trying to implement "Automate Road Surface Investigation Using Deep Learning" sample procedures in my pc. but while trying to execute the code
data = prepare_data(data_path,
                    batch_size=4,
                    chip_size=500,
                    seed=42,
                   dataset_type='PASCAL_VOC_rectangles')
I get the following error.
I have checked the conda list it. the environment has the necessary packages it needs to be there. I am attaching the conda list as well. Can someone please help me on what am I doing wrong?
(arcgis-fastai) C:\Users\username\AppData\Local\ESRI\conda\envs\arcgis-fastai>conda
 list
# packages in environment at C:\Users\username\AppData\Local\ESRI\conda\envs\arcgis
-fastai:
arcgis                    1.7.1                  py36_969    esri
arcgispro                 2.4                           0    esri
asn1crypto                1.3.0                    py36_0
atomicwrites              1.3.0                    py36_1
attrs                     19.3.0                     py_0
backcall                  0.1.0                    py36_0
beautifulsoup4            4.8.2                    py36_0
blas                      1.0                         mkl
bleach                    3.1.0                      py_0
bottleneck                1.3.1            py36h8c2d366_0
ca-certificates           2020.1.1                      0
certifi                   2019.11.28               py36_0
cffi                      1.13.2           py36h7a1dbc1_0
cftime                    1.0.0b1          py36h452e1ab_0
chardet                   3.0.4                 py36_1003
colorama                  0.4.3                      py_0
cryptography              2.8              py36h7a1dbc1_0
cudatoolkit               10.0.130                      0
cycler                    0.10.0           py36h009560c_0
cymem                     2.0.2            py36h6538335_0    fastai
cython-blis               0.2.4            py36hfa6e2cd_1    fastai
dataclasses               0.6                        py_0    fastai
decorator                 4.4.1                      py_0
defusedxml                0.6.0                      py_0
despatch                  0.1.0                    py36_0    esri
entrypoints               0.3                      py36_0
et_xmlfile                1.0.1            py36h3d2d736_0
fastai                    1.0.54                   py36_0    esri
fastcache                 1.1.0            py36he774522_0
fastprogress              0.2.2                      py_0    fastai
freetype                  2.9.1                    vc14_0  [vc14]  esri
future                    0.18.2                   py36_0
gdal                      2.3.3              arcgispro_11  [arcgispro]  esri
h5py                      2.9.0           py36_arcgispro_0  [arcgispro]  esri
html5lib                  1.0.1                      py_0
icc_rt                    2019.0.4            arcgispro_0  [arcgispro]  esri
idna                      2.8                      py36_0
imageio                   2.6.1                    py36_0
importlib_metadata        1.4.0                    py36_0
intel-openmp              2019.4            arcgispro_245  [arcgispro]  esri
ipykernel                 5.1.4            py36h39e3cac_0
ipython                   7.11.1           py36h39e3cac_0
ipython_genutils          0.2.0                    py36_0
ipywidgets                7.5.1                      py_0
jdcal                     1.4.1                      py_0
jedi                      0.16.0                   py36_0
jinja2                    2.10.3                     py_0
jpeg                      9b                   hb83a4c4_2
json5                     0.8.5                      py_0
jsonschema                3.2.0                    py36_0
jupyter_client            5.3.4                    py36_0
jupyter_console           6.1.0                      py_0
jupyter_core              4.6.1                    py36_0
jupyterlab                1.2.5              pyhf63ae98_0
jupyterlab_server         1.0.6                      py_0
keyring                   21.1.0                   py36_0
kiwisolver                1.1.0            py36ha925a31_0
libpng                    1.6.37               h2a8f88b_0
libsodium                 1.0.16               h9d3ae62_0
libtiff                   4.1.0                h56a325e_0
m2w64-gcc-libgfortran     5.3.0                         6
m2w64-gcc-libs            5.3.0                         7
m2w64-gcc-libs-core       5.3.0                         7
m2w64-gmp                 6.1.0                         2
m2w64-libwinpthread-git   5.0.0.4634.697f757               2
markupsafe                1.1.1            py36he774522_0
matplotlib                3.0.3                   py36_0e  [arcgispro]  esri
mistune                   0.8.4            py36he774522_0
mkl                       2019.3            arcgispro_203  [arcgispro]  esri
mkl_fft                   1.0.12           py36h14836fe_0
mkl_random                1.0.2            py36h343c172_0
more-itertools            8.0.2                      py_0
mpmath                    1.1.0                    py36_0
msys2-conda-epoch         20160418                      1
murmurhash                1.0.2            py36h33f27b4_0
nb_conda                  2.2.1                    py36_0
nb_conda_kernels          2.2.2                    py36_0
nbconvert                 5.6.1                    py36_0
nbformat                  5.0.4                      py_0
netcdf4                   1.5.0.1         py36_arcgispro_1  [arcgispro]  esri
networkx                  2.4                        py_0
ninja                     1.9.0            py36h74a9793_0
nose                      1.3.7                    py36_2
notebook                  6.0.3                    py36_0
numexpr                   2.6.9            py36hdce8814_0
numpy                     1.16.2           py36h19fb1c0_0
numpy-base                1.16.2           py36hc3f5095_0
nvidia-ml-py3             7.352.0                    py_0    fastai
olefile                   0.46                       py_0
openpyxl                  3.0.3                      py_0
openssl                   1.1.1d               he774522_3
packaging                 20.1                       py_0
pandas                    1.0.0            py36h47e9c7a_0
pandoc                    2.2.3.2                       0
pandocfilters             1.4.2                    py36_1
parso                     0.6.0                      py_0
pickleshare               0.7.5                    py36_0
pillow                    7.0.0            py36hcc1f983_0
pip                       20.0.2                   py36_1
plac                      0.9.6                    py36_0
pluggy                    0.13.1                   py36_0
preshed                   2.0.1            py36h33f27b4_0
prometheus_client         0.6.0                    py36_0    esri
prompt_toolkit            3.0.3                      py_0
py                        1.8.1                      py_0
pycparser                 2.19                       py_0
pygments                  2.5.2                      py_0
pyopenssl                 19.1.0                   py36_0
pyparsing                 2.4.6                      py_0
pypdf2                    1.26.0                     py_2    esri
pyrsistent                0.15.7           py36he774522_0
pyshp                     1.2.12                   py36_0
pysocks                   1.7.1                    py36_0
pytest                    5.3.4                    py36_0
python                    3.6.8                h9f7ef89_7
python-dateutil           2.8.1                      py_0
pytorch                   1.1.0           py3.6_cuda100_cudnn7_1    esri
pytz                      2019.3                     py_0
pywavelets                1.1.1            py36he774522_0
pywin32                   223              py36hfa6e2cd_1
pywin32-ctypes            0.2.0                 py36_1000
pywinpty                  0.5.7                    py36_0
pyyaml                    3.12                     py36_0
pyzmq                     18.1.0           py36ha925a31_0
requests                  2.22.0                   py36_1
scikit-image              0.15.0                   py36_0    esri
scipy                     1.2.1            py36h29ff71c_0
send2trash                1.5.0                    py36_0
setuptools                45.1.0                   py36_0
simplegeneric             0.8.1                    py36_2
six                       1.14.0                   py36_0
soupsieve                 1.9.5                    py36_0
spacy                     2.1.8            py36he980bc4_0    fastai
sqlite                    3.30.1               he774522_0
srsly                     0.1.0            py36h6538335_0    fastai
sympy                     1.5.1                    py36_0
terminado                 0.8.3                    py36_0
testpath                  0.4.4                      py_0
thinc                     7.0.8            py36he980bc4_0    fastai
tk                        8.6.8                hfa6e2cd_0
torchvision               0.2.2                      py_3    pytorch
tornado                   6.0.3            py36he774522_0
tqdm                      4.42.0                     py_0
traitlets                 4.3.3                    py36_0
typing                    3.6.4                    py36_0
urllib3                   1.25.8                   py36_0
vc                        14.1                 h0510ff6_4
vs2015_runtime            14.16.27012          hf0eaf9b_1
wasabi                    0.2.2                      py_0    fastai
wcwidth                   0.1.7                    py36_0
webencodings              0.5.1                    py36_1
wheel                     0.34.1                   py36_0
widgetsnbextension        3.5.1                    py36_0
win_inet_pton             1.1.0                    py36_0
wincertstore              0.2              py36h7fe50ca_0
winkerberos               0.7.0                    py36_1
winpty                    0.4.3                         4
x86cpu                    0.4                      py36_1    esri
xlrd                      1.2.0                      py_0
xlwt                      1.3.0            py36h1a4751e_0
xz                        5.2.4                h2fa13f4_4
zeromq                    4.3.1                h33f27b4_3
zipp                      0.6.0                      py_0
zlib                      1.2.11               h62dcd97_3
zstd                      1.3.7                h508b16e_0
Regards,
Tauhid
DanPatterson_Retired
Did you have any problems completing the required steps?  What was your data path?
Automate Road Surface Investigation Using Deep Learning | ArcGIS for Developers
Md_TauhidulIslam
New Contributor II
Hi Dan,
Tryied to replicate the issue in ArcGIS notebook Sandbox got the below error.
Any idea?
Regards,
Tauhid
Md_TauhidulIslam
New Contributor II
Hi Dan,
I have successfully transferred the sample data using Automate Road Surface Investigation Using Deep Learning | ArcGIS for Developers  into the "C:\temp\TrainingData" which is my data path. In that folder I have the subfolders images and labels.
When I try to execute the script
                    batch_size=4,
                    chip_size=500,
                    seed=42,
It raised the error that fastai and pytorch is not installed.
Regards,
Tauhid
by Anonymous User
Not applicable
Have you installed the required dependencies for arcgis.learn module, you need to install the required dependencies in a clean environment and use that
conda install -c esri arcgis fastai pillow scikit-image --no-pin
