arcgis.features.manage_data overlay_layers method does not make use of context={"overwrite":True} parameter.
1891
04-18-2023 07:46 AM
BennyFriedman2
Hello all.
I am using the overlay_layers method to erase building footprints from a layer of ground conditions. I'd like to do this by calling the overlay_layers method on the grounds layer and passing in the buildings layer as the overlay feature, then setting the output_name equal to the grounds layer name so that the cliped grounds layer replaces the original grounds layer. See code below:
overlay_layers(grounds_layer, buildings_layer, overlay_type='Erase', output_name=f"{grounds_title}", context={"overwrite": True})
Running hat code returns the error: {Exception}Job failed.
However, if I set the output_name to something like "{grounds_title}_clipped" the job runs successfully and a clipped version is added to my arcgis online content.
This leads me to believe it is not a problem with the name, or underlying data but is in fact an issue with the overwrite parameter.
Thank you for any help.
@DavidPike @KevinHibma @David_McRitchie
BennyFriedman2
Found the solution. To get the overwrite to work correctly you need to pass the layer object of the layer you'd like to overwrite into the output_name parameter.
grounds_clip = overlay_layers(grounds_layer, buildings_layer, overlay_type='Erase', output_name=grounds_layer, context={"overwrite": True})
BennyFriedman2
David_McRitchie
Hey Benny apologies for not getting a chance to look at this, I was away on holiday. Glad to see you got it all sorted though!
Please feel free to @ mention me in future and more than happy to help where I can.
Esri UK -Technical Support Analyst
