2.7.1 Python env works in ArcGIS Pro, in Notebooks but not in VS Code
755
03-01-2021 07:10 AM
MortenHjelmsmark1
New Contributor II
I have cloned and activated my Python Environment and it works fine in ArcGIS  Pro and when running Jupyter lab, but when I try to debug a script tool in VS code using the cloned environment, I get a strange error: ModuleNotFoundError: No module named 'ptyprocess'??
If I try to run pip install ptyprocess it then throws: No module named 'fcntl' which doesn't exist for windows?
The issue must have come with the 2.7.1 upgrade because it hasn't been an issue with previous versions.
Does anybody know of a workaround?
by Anonymous User
Not applicable
Hi Morten,
What happens if you activate the cloned environment in ArcGIS Pro and run the problematic script/code against ArcGIS Pro's built-in IDE?
If this is what you meant by "it works fine in ArcGIS Pro", then I apologize for misinterpreting.
-Calvin
MortenHjelmsmark1
New Contributor II
Running the script in ArcGIS Pro works, but then I cannot debug. I have used this procedure for years and it's the first time I experience this problem.
