No Tricks, Just Treats with the New v1.7.0 Python API Release! 🎃
4448
10
10-31-2019 11:48 AM
by Anonymous User
Not applicable
4 10 4,448
Happy Halloween! The ArcGIS API for Python has just released its newest version, 1.7.0. View the release notes here to see what's new and what bugs have been fixed. Visit our landing page for all other information about the Python API.
You can install this newest version via conda:
conda install -c esri arcgis
or pip:
pip install arcgis
We can't wait to hear what you think of this release!
10 Comments
Subu_Swaminathan_GISP
New Contributor III
David,
I am trying to upgrade an existing clone env using
conda upgrade -c esri arcgis
I get the following message. What am i missing here?
# All requested packages already installed.
# packages in environment at xcxxsd\arcgispro-py3-clone:
arcgis                    1.6.2           py36h4f45381_633    esri
New Contributor III
Follow Dan's instruction at  https://community.esri.com/thread/243171-how-to-upgrade-to-170  to get around this issue.
HiromuNAKAMURA
New Contributor II
Do we need Enterprise 10.8 (prerelease) for some of the new functionalities of the API?
or 10.7.1 is enough for them?
TedChapin
Occasional Contributor III
Why is the update not listed in the Pro backstage Python Package Manager? Shouldn't we be able to select it under "Update Packages" and click the Update button?
by Anonymous User
Not applicable
Hi Hiromu,
The API should be compatible with 10.7.1 enterprise. You will not be able to use 10.8 functionality from the Python API, but most of the endpoints in the REST API are the same. Let us know if you're running into specific problems!
- David
by Anonymous User
Not applicable
Hi Ted,
What version of Pro are you using? Pro's python environment normally "pins" packages to specific version ranges. For example, I believe Pro 2.4 pins the Python API to the 1.6.* series. Pro 2.5 should come with 1.7.0.
You can get around this on earlier versions of Pro by using a cloned environment, and using the "--no-pin" flag when running conda from the command prompt (i.e. "Python Command Prompt"). The command might look like this:
conda install -c esri arcgis --no-pin
Proceed at your own risk, sometimes updating packages outside of the recommended pins can cause instability! This is why you should use a cloned environment -- you can always delete the clone if things become unstable.
DanPatterson_Retired
Of if an update goes bad, you can always rollback the clock
Restoring environment to a previous revision – Anaconda Knowledge Base
TedChapin
I am at 2.4. I'll wait for the API that rolls with Pro.
HiromuNAKAMURA
New Contributor II
Hi David,
Thank you for your reply! I am very excited with a lot of new funtionalities!
RobertJones11
New Contributor II
In case it might help someone: I got an error when attempting this step of the offline install with the latest Anaconda and Python API releases:
Create a new environment, including python and six packages:
conda create -n <my_env_name> python six
The error I got was as follows:
Executing transaction: | b'\'"C:\\ProgramData\\Anaconda3\\envs\\testenv\\Scripts\\jupyter-nbextension.exe"\' is not recognized as an internal or external command,\noperable program or batch file.\n\'"C:\\ProgramData\\Anaconda3\\envs\\testenv\\Scripts\\jupyter-nbextension.exe"\' is not recognized as an internal or external command,\noperable program or batch file.\n'
/ b'Manually uninstall any prior version of arcgis widget using:\n\t"jupyter nbextension uninstall arcgis --user" and \n\t"jupyter nbextension uninstall arcgis"\n\'"C:\\ProgramData\\Anaconda3\\envs\\testenv\\Scripts\\jupyter-nbextension.exe"\' is not recognized as an internal or external command,\noperable program or batch file.\n\'"C:\\ProgramData\\Anaconda3\\envs\\testenv\\Scripts\\jupyter-nbextension.exe"\' is not recognized as an internal or external command,\noperable program or batch file.\n'
done
I resolved this issue by including jupyter when creating the environment, i.e. I executed the following:
conda create -n <my_env_name> python six jupyter
