Quite often, people wonder how to use the ArcGIS API for Python to update layer symbology. After a quick search through posts and documentation, one may discover that there are a number of ways to accomplish this and find oneself uncertain of how to proceed. If you land on this page my hope is that everything will start to make a bit more sense. In this post I'll go over:
If the above all seem the same don't worry - presently, the distinctions between #1, #2, and #3 will become clear and you will get a better sense of when you might want to choose one method over another.
Note: Although I'm illustrating how to update symbology, you can apply the same concepts to update/configure other properties such as pop-ups, labels, etc. I encourage you to build upon the below standalone scripts or use only the parts you need!
How to Update Layer Symbology in a Web Map:
Let's suppose you add this Map Service to your content in ArcGIS Online/Portal for ArcGIS: https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer
You add the item to a Web Map and for a little while it suits your needs:
But one day you decide that you don't really like the color orange and would get more use out of the Web Map if you could better visualize total population of each county.
After some time, you settle on the symbology included in the attached webmaplyr.json. It's a bit a long so I won't include it here - this is fine because you probably won't want to define the JSON in your script anyway, preferring to read from a file.
If you don't know where to get started as far as generating your own JSON don't fret. Simply start by creating a Web Map exactly as you want it to appear (apply styles, labels, options, etc.). From there, you can go to (where itemID is the item id of the Web Map):
- Portal: https://machine.domain.com/portal/sharing/rest/content/items/<itemID>/data
- ArcGIS Online: https://www.arcgis.com/sharing/content/items/<itemID>/data
- Share (temporarily) the item to 'Everyone' if you don't want to have to supply a token.
Alternatively, you can get the JSON using the ArcGIS API for Python with a few lines:
from arcgis import GIS import json conn = GIS("https://machine.domain.com/portal", "admin", "password") item = conn.content.get(<itemID>) item_data = item.get_data() # Include the below line for prettified JSON print(json.dumps(item_data, indent=4, sort_keys=True))
The below script illustrates how to read your prepared JSON from a file and apply it to the Web Map:
import json, sys
def search_item(conn,layer_name):
search_results = conn.content.search(layer_name, item_type='Web Map')
proper_index = [i for i, s in enumerate(search_results) if
'"'+layer_name+'"' in str(s)]
found_item = search_results[proper_index[0]]
get_item = conn.content.get(found_item.id)
return get_item
def update_wm_layerdef(item):
print("*******************ORIGINAL DEFINITION*********************")
# Open JSON file containing symbology update
with open('/path/to/webmaplyr.json') as json_data:
data = json.load(json_data)
# Set the item_properties to include the desired update
item_properties = {"text": json.dumps(data)}
# 'Commit' the updates to the Item
item.update(item_properties=item_properties)
# Print item_data to see that changes are reflected
new_item_data = item.get_data()
print("***********************NEW DEFINITION**********************")
print(json.dumps(new_item_data, indent=4, sort_keys=True))
def main():
# Search for item, get item data)
item = search_item(conn, 'wm_lyrsym')
if __name__ == '__main__':
sys.exit(main())
After the script runs, you end up with the below:
How to Update Portal/ArcGIS Online Item Symbology:
The difference here is subtle. In Option #1, the item being updated is a Web Map. Here, the item being updated is a Feature/Map Image Service Layer. The service might be something you published to ArcGIS Online/Portal for ArcGIS, or a Map/Feature Service you added as an item to your content.
Option #1 is great if all you need to do is change the styles in a Web Map, but perhaps you need to change the style for an item in your Organization. Since this item is used by many people (and deliverables are occasionally provided to stakeholders outside of the organization) you wish to standardize its appearance.
In this example, I use the same Map Service as before (https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer) and perform a similar update to the symbology, only on the Layer item itself.
Note that this example is a bit more specific on how the symbology is updated:
layer_def = item_data['layers'][3]['layerDefinition']
You might wonder why this is included:
else:
print("There is no Layer Definition at the moment..creating one...")
create_layer_def(item)
import json, sys
def search_layer(conn,layer_name):
search_results = conn.content.search(layer_name, item_type='*')
return get_item
def update_layer_def(item):
if item_data is not None:
# Here note we are changing a specific part of the Layer Definition
with open('/path/to/drawingInfo.json') as json_data:
# Set the drawingInfo equal to what is in JSON file
layer_def['drawingInfo'] = data
item_properties = {"text": json.dumps(item_data)}
else:
def create_layer_def(item):
with open('/path/to/complete.json') as json_data:
print("*********************CREATED DEFINITION************************")
def main():
item = search_layer(conn, 'earl_api_usalyraw')
# Attempt to update Layer Definition
sys.exit(main())
How to Update Feature Service Symbology:
In this last example, I illustrate how to update symbology on a Feature Service Layer. Behind the scenes, this method really just performs this operation: Update Definition (Feature Layer)—ArcGIS REST API: Services Directory | ArcGIS for Developers
So, what's the difference here and when would you want to use this approach?
For this example, I published a Hosted Feature Service containing 2 layers:
The original Feature Service looks like this:
The JSON for this example isn't very long. I just make a few changes to color and width on the States/Provinces layer:
"drawingInfo": {
"renderer": {
"type": "simple",
"symbol": {
"type": "esriSFS",
"style": "esriSFSSolid",
"color": [
202,
46,
204,
105
"outline": {
"type": "esriSLS",
"style": "esriSLSSolid",
"color": [
10,
10,
210,
55
"width": 0.5
"scaleSymbols": true,
"transparency": 0,
"labelingInfo": null
In this scenario, since we're updating a Feature Service and not an item we need to use arcgis.features.
from arcgis.features import FeatureLayerCollection
import json, sys
search_results = conn.content.search(layer_name, item_type='Feature Layer')
flc = FeatureLayerCollection.fromitem(found_item)
return flc
def update_layer_def(layer):
with open('/path/to/hosted_drawinfo_lyr.json') as json_data:
layer.manager.update_definition(data)
print("*******************UPDATED DEFINITION**********************")
print(layer.properties)
def main():
flc = search_layer(conn, 'layerdef')
layer = flc.layers[1]
sys.exit(main())
The update result:
That concludes this overview on how to update layer symbology. Hopefully with this guide you can get a good sense of how to implement similar workflows in your organization!
