Hi everybody,
I've been working on displaying a multi-dimensional mosaic dataset in a web app with js (which wouldn't have been possible without this forum so far: thank you).
I'm nearly done with everything, but there's one lingering problem:
My dataset intends to show scenarios in five year increments starting at +5 years and going to +100 years (in the future starting from when the user is looking at the data [or intends to implement said scenario]).
Currently, the date field is set in years and I have added 2000 to each of the scenarios so that TimeSlider would work. So my date slider looks like:
After changing a few things in the CSS, namely:
<SPAN class="selector token">#timeSlider</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="property token">position</SPAN><SPAN class="punctuation token">:</SPAN> absolute<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">width</SPAN><SPAN class="punctuation token">:</SPAN> 33%<SPAN class="punctuation token">;</SPAN>
<SPAN class="property token">left</SPAN><SPAN class="punctuation token">:</SPAN> 33%<SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="selector token">.esri-time-slider__time-extent,
.esri-time-slider__min,
.esri-time-slider__max,
.esri-slider__tick.minorTick</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN> none <SPAN class="important token">!important</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>It looks like this:
Just in case, here's the JS used to create TimeSlider:
<SPAN class="comment token">// create and add time slider to view</SPAN>
<SPAN class="keyword token">const</SPAN> timeSlider <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">TimeSlider</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'timeSlider'</SPAN><SPAN class="punctuation token">,</SPAN>
mode<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'instant'</SPAN><SPAN class="punctuation token">,</SPAN>
view<SPAN class="punctuation token">:</SPAN> view
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
view<SPAN class="punctuation token">.</SPAN>ui<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>timeSlider<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'manual'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// wait until the layer view is loaded</SPAN>
<SPAN class="keyword token">let</SPAN> timeLayerView<SPAN class="punctuation token">;</SPAN>
view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">whenLayerView</SPAN><SPAN class="punctuation token">(</SPAN>layer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>layerView<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
timeLayerView <SPAN class="operator token">=</SPAN> layerView<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> fullTimeExtent <SPAN class="operator token">=</SPAN> layer<SPAN class="punctuation token">.</SPAN>timeInfo<SPAN class="punctuation token">.</SPAN>fullTimeExtent<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">const</SPAN> start <SPAN class="operator token">=</SPAN> fullTimeExtent<SPAN class="punctuation token">.</SPAN>start<SPAN class="punctuation token">;</SPAN>
<SPAN class="comment token">// set up time slider properties</SPAN>
timeSlider<SPAN class="punctuation token">.</SPAN>fullTimeExtent <SPAN class="operator token">=</SPAN> fullTimeExtent<SPAN class="punctuation token">;</SPAN>
timeSlider<SPAN class="punctuation token">.</SPAN>values <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>start<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
timeSlider<SPAN class="punctuation token">.</SPAN>stops <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
interval<SPAN class="punctuation token">:</SPAN> layer<SPAN class="punctuation token">.</SPAN>timeInfo<SPAN class="punctuation token">.</SPAN>interval
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>What I would like is an *animated* slider with labels in 5 year increments starting at 5 and ending at 100.
So the way I see, there would be three ways to 'solve' this problem:
- Somehow hack time-enabled layers and TimeSlider JS to accept values less than 100 as temporal
- Allow TimeSlider to configure user-defined labels
- Use CSS to define labels
Are any of these even possible?
