WMTS Web Map In Basemap Gellery Problem
3643
04-17-2015 02:44 AM
EduardLepner1
Hi!
Our ArcGIS Portal has WMTS Maps. We'd like to switch them using Basemap gallery widget. But when you do so it throws error "TypeError: this.tileInfo.spatialReference.toJson is not a function", however everything works fine with ESRI Map Service layers.
I added a sample which demonstrates this issue.
Thanks in advance.
Tags (3)
Arpa_PiemonteGeoportal_Team
Occasional Contributor II
We have the same problem but in AGOL.
We can create and use WMTS  as basemaps in the AGOL Map viewer, but in any other js webapplication (ie agol  templates viewers) the wmts basemap doesn't 'appear.
Searching with Firefox firebug we noticed this error while we try to switch from standard basemap (tiled rest map service)  to WMTS basemap from the basemap gallery:
we use the same spatial refeence ( webmaercator) and the same tiling schema.
Any help is appreciated.
