web app builder busy indicator client side function
2204
10-22-2020 10:04 AM
wadsonmakari
Hi all,
I am have extended web app builder and built a custom widget. I have a client side function that takes between 10 and 20 seconds to run. The function is client side and does not make a call to the server.
I would like to indicate to the user that the function is running when a user calls this function and also show when the function is finished. The function is called via a click event on a button.
I have used the "dijit/ProgressBar" but this seems to work with requests made to the server but not client side functions.
Typically I use it as follows
html.setStyle("domNode", 'display', 'block');
"domNode".set('label','processing please wait...');
After the function is finished
 html.setStyle("domNode", 'display', 'none');
Is it possible to such a work flow with client side functions?
RobertScheitlin__GISP
Sure. The way to ensure that the loading shelter appears is call shelter.show() then add a setTimeout for 500 (half a second) and inside the setTimeout function call your actual code.
Wadson,
   If you look at otb widget in WAB the way they handle this is to use "jimu/dijit/LoadingShelter" in the Widget.html and just call that object data-dojo-attach-point in the widget.js code like:
this.shelter.show(); and this.shelter.hide();
wadsonmakari
Thank you Robert for the suggestion. However it is not behaving in the way that I expected. I have implemented as follows
this.myFunction(); //this function takes between 10 - 20 seconds to run(doing client side analysis using esri geometry engine)
At the end of myFunction I have this.shelter.hide();
I do not see the Loading shelter at all. If I put an alert message after this.shelter.show(); I can see the loading shelter and it is hidden when the function finishes.
I call myFunction via a click event on a button on my widget. Basically I would like the following workflow;
1 User clicks button
2 widget tells user that processing has started and show shelter with message
3 hide shelter when processing is finished.
Could this be due to the fact that Javascript is single threaded? Is there another way I can achieve this?
wadsonmakari
Thank you very much that worked very well.
