Version 2.1 of the ArcGIS API for JavaScript released
1220
14
09-20-2010 09:21 AM
KellyHutchins
Esri Frequent Contributor
Version 2.1 of the ArcGIS API for JavaScript was released this morning. Check out the server blog for more details:
http://blogs.esri.com/Dev/blogs/arcgisserver/default.aspx
derekswingley1
Very, very nice. Congrats on the release and thanks for the heads up!
JoeShmoe
Can we get a new local installs for 2.1 under Concepts -> Inside the API -> Frequently Asked Questions -> Can the ArcGIS JavaScript API be installed locally?
Thanks!
mikewebster
I 2nd the request for the updated download.
KellyHutchins
We are working on preparing the local download. I'll update this thread with the link once it's ready.
AndyBurns
Hi Kelly
Sorry to bump this but do you have a possible ETA on when the local download would be available? We require it as soon as possible.
Thanks.
ADD: Does anyone know where to get this version 10.01 of ArcGIS Server? We only have v10 and cannot find a SP or update out on ESRI anywhere.
HamidYunus
where did u read about 10.01?
AndyBurns
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp_start.htm
Updates
Added the following new properties, methods, events and constants to existing objects.
    * Added the ability to query for a feature count to the QueryTask and FeatureLayer classes. These new methods only work for layers published using ArcGIS Server 10 sp1 or greater.
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi_start.htm
The legend supports the following layer types: ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer, FeatureLayer. If the layer is an ArcGISDynamicMapServiceLayer or ArcGISTiledMapServiceLayer created using ArcGIS Server 10.01 or higher the legend is generated using the REST Map Service legend resource.
http://mapservice-url/legend
If the layers are version 10 or lower the legend is created using the ArcGIS.com legend service. In order to use the ArcGIS.com legend service your map service needs to be publicly accessible and your application must be able to access ArcGIS.com.
KevinGooss
I noticed that too. What is 10.01?
KellyHutchins
The FAQ was updated today to include the local install for 2.1. http://help.arcgis.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/inside_faq.htm
Thanks!
