Using server-side renderer for image service
1239
04-26-2019 06:36 PM
ShannonDeArmond
I have a Living Atlas layer shared on my portal (not accessible outside my intranet sadly). The layer includes some pre-built raster functions. What I'm trying to do is load the layer into a webmap using the 3.28 ArcGIS JS API and apply a specific raster function to affect the appearance.
Screen shot of raster functions descriptions from rest page
Based on my reading here and here, it seems like this should be possible. The layer loads just fine but the raster function is not being applied. It's coming in as the default grey-scale stretch symbology and with no helpful errors in the console to help me along. Can anyone point me in the right direction?
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Raster Function Test</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.28/esri/css/esri.css">
    <style>
      html,
      body,
      #mapDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script src="https://js.arcgis.com/3.28/"></script>
    <script>
      require([
	      'esri/map',
        'esri/layers/ArcGISImageServiceLayer',
        'esri/layers/ImageServiceParameters',
        'esri/layers/RasterFunction',
        'dojo/domReady!'
        function(
          Map,
          ArcGISImageServiceLayer,
          ImageServiceParameters,
          RasterFunction
        var map = new Map("mapDiv", {
          basemap: "topo",
          center: [-122.45, 37.75],
          zoom: 13,
        var serviceRFT = new RasterFunction({
          functionName: "Slope_Degrees_Map",
          variableName: "Raster"
        var params = new ImageServiceParameters();
        params.noData = 0;
        var slopeImageLyr = new ArcGISImageServiceLayer("https://data.farwestern.com/portal/sharing/servers/a1ba14d09df14f42ad6ca3c4bcebf3b4/rest/services/WorldElevation/Terrain/ImageServer", {
          visible: true,
          opacity: 0.7,
          renderingRule: serviceRFT,
          imageServiceParameters: params
        map.addLayer(slopeImageLyr);
  </script>
</head>
<body>
  <div id="mapDiv"></div>
</body>
</html>
UndralBatsukh
Hi there,
Set the renderingRule on imageServiceParameters in the layer constructor. So in your code, move the rendering rules to imageServiceParameters. The reason is that renderingRule is not an option for the image layer constructor but imageServiceParameters is.
Hope this makes sense,
-Undral
UndralBatsukh
Hi there,
-Undral
ShannonDeArmond
Thank you for your help, Undral! That did the trick.
