I'm trying to use the arcgis rest api to upload kml file to the portal. I made addItem request and then addPart request to upload the file itself. The documentation does not mention how to send the file, so I read the content of the file as text and send it but I'm getting Internal Server Error response.
Here is my code (I also added the js file as attachment):
// get list of files
var files = this.fileSelect.files;
// continue only if the user select one (or more) files
if (files.length > 0) {
this.uploadButton.innerHTML = "Uploading..";
var file = files[0];
fetch('https://www.arcgis.com/sharing/rest/content/users/*****/addItem', {
method: 'post',
headers: {
'Content-Type': 'application/x-www-form-urlencoded;charset=UTF-8'
body: 'token='+encodeURIComponent(token)+'&f=json&title='+encodeURIComponent(file.name)+'&type=KML&filename='+encodeURIComponent(file.name)+'&multipart='+encodeURIComponent(true)
.then(res => res.json())
.then(res => {
return new Promise(resolve => {
var id = res.id;
var fileReader = new FileReader();
// when finish to read the file, make request with the content of the file
fileReader.onload = (e) => {
let data = e.target.result;
fetch('https://www.arcgis.com/sharing/rest/content/users/****/items/'+id+'/addPart', {
method: 'post',
headers: {
body: 'token='+token+'&f=json&partNum=1&file='+encodeURIComponent(data)
.then(res => resolve(res));
// read file content
fileReader.readAsText(file);
.then(res => {
console.log(res); // THIS LINE LOGS "500 - INTERNAL SERVER ERROR..."
if (res.success) {
return fetch('https://www.arcgis.com/sharing/rest/content/users/*****/items/'+id+'/commit', {
method: 'post',
} else {
return null; // ...THEN GOES HERE
.then(res => {
if (res) {
return res.json();
} else {
return undefined; // ...AND THEN RETURN UNDEFINED!
.then(res => {
console.log(res);
Could someone please explain how to upload small file (kml, less than 5mb) to the portal using arcgis rest api (javascript)?
Thank you!
p.s sorry if I have grammar mistakes (I'm not native english speaker) ..
In my experience the best way to approach this is to manually add the KML as a portal item using the Add Item option from My Contents and use your browser's dev tools to look at the request that gets sent (chrome has a preserve log option to make sure the network log keeps the request). You can use this request as a template for what your request has to do.
That aside, here's some code I've used to upload to upload files as portal items using esri/request:
// user is a portalUser.
// fileList is an array of files.
// tags is an array of strings
function addFileaAsPortalItem(user, fileList, tags){
const file = fileList[0];
let form = new FormData();
form.append('file',file);
form.append("f", "json");
form.append("title", file.name);
form.append("name", file.name);
form.append("type",'KML');
form.append("token", <server token>);
form.append("filename", file.name);
form.append("tags", tags.join());
return esriRequest(`${user.userContentUrl}/addItem`,{
method: 'post',
query: form
I'm not sure if this will fail when the file is too large. I've used it to upload images, kml, text documents, and more. It also may be a good idea to use esri/request for this, as opposed to the fetch api.
method: 'post',
query: form
That's working. Thanks!
