Hello every superiors:
when I move a graphic geometry to another place , then i use this js
currentFeatureLayer.applyEdits(null, [evt.graphic], null,function(result){
createLog(logObj);
},function(err){
flag4log = -1;
to update databse ,then the graphic geometry record become two row in oracle database, the two record all colums the same。
hope you can help me ,thanks very much 。
Does the evt.graphic have an Object ID for a feature that exists in your data set?
applyEdits(adds?, updates?, deletes?, callback?, errback?)
Apply edits to the feature layer. Only applicable for layers in a feature service.
Graphic[]
> updatesArray of features whose geometry and/or attributes have changed. Features must have a valid OBJECTID.
You can check this by logging the evt.graphic:
console.log(evt.graphic);
Graphic[]
Dear Mr. oearley
Thanks very much for your answer.
The objectid really has the same ,but the objectid is auto create by
SELECT registration_id FROM sde.table_registry WHERE table_name = 'RESOURCEALARM' and owner = 'SDE';
I don't know how can it has same.
