Uncaught TypeError: Cannot read property 'PeFactory' of null
1393
08-19-2019 11:03 PM
NadirHussain
Occasional Contributor II
Dear All,
I am facing this problem.when i want to convert into utm coordinates i am getting the fallowing error.
i did not understand what is null in my code i check every thing.please help.
Thanks in advance.
require([
"esri/map",
"esri/layers/FeatureLayer",
"esri/dijit/Search",
"esri/geometry/coordinateFormatter",
"esri/SpatialReference",
"esri/geometry/Point",
"esri/InfoTemplate",
"dojo/domReady!"
], function (Map, FeatureLayer, Search,coordinateFormatter,SpatialReference,Point, InfoTemplate) {
var lt="44.0505";
var lg="17.5183";
var pt = new Point(lt, lg, new esri.SpatialReference({ wkid: 4326 }));
alert(pt.x+"_HELLO____"+pt.y);
var str = coordinateFormatter.toUtm(pt, "north-south-indicators", true);
alert(str);
by Anonymous User
Not applicable
Hi Nadir,
You just need to add coordinateFormatter.load(); statement after alert (pt.x+"_HELLO___" + pt.y);
Null because coordinateFormatter is not loaded yet.
I share with you sample code : https://codepen.io/thanhtetaung/pen/BaBLxaV how to use it.
On mouse move on the map, you can see UTM format at lower left corner.
by Anonymous User
Not applicable
Hi Nadir,
