unable to get feature when i select a value in second drop box
568
12-19-2019 05:04 AM
SatyanarayanaNarmala
Hi all,
i have 2 layers, zone and circle. when i filter (filter.png)  zone select a name it will zoom to that particular zone and print on console as 1. And when i select zone and circle combination only 0 zero records is fetched as seen in console (s.png).
$(document).on("change", "#Zone_list", function () {
                if ($("#Zone_list").val() == "All Zones") {
                    $("#Circle_list").empty();
                    $("#table_title").text("All Zones");
                    map.addLayer(district_layer);
                    map.removeLayer(mandal_layer);
                    map.setExtent(district_layer.fullExtent);
                    basicOnLoadFun();
                } else {
                    $("#table_title").text("Zone: " + $("#Zone_list :selected").text());
                    setMapFeatureToExtent(QueryTask, Query, district_url, 'sde.sde.ghmc_zones_pt1.zoneid = ' + $("#Zone_list").val());
                    var query_con = 'sde.sde.GHMC_Circles_pt1.zone_id = ' + $("#Zone_list").val();
                    selectedDistrict(query_con);
            $(document).on("change", "#Circle_list", function () {
                if ($("#Circle_list").val() == "All Circles") {
                } else {
                    var condition = 'sde.sde.GHMC_Circles_pt1.circle = ' + $("#Circle_list").val() + ' AND sde.sde.GHMC_Circles_pt1.zone_id = ' + $("#Zone_list").val();
                    setMapFeatureToExtent(QueryTask, Query, mandal_url, condition);
            function selectedDistrict(query_con) {
                map.removeLayer(district_layer);
                mandal_layer.setDefinitionExpression(query_con);
                map.addLayer(mandal_layer);
                field_key = "sde.sde.circlepara." + $('input[name=Indecator]:checked').val();
                var out_fields = "sde.sde.GHMC_Circles_pt1.zone || sde.sde.GHMC_Circles_pt1.zone_id || sde.sde.GHMC_Circles_pt1.cir_name || sde.sde.GHMC_Circles_pt1.circle ||
                getAttributes(Query, QueryTask, query_con, mandal_url, "sde.sde.GHMC_Circles_pt1.cir_name||sde.sde.GHMC_Circles_pt1.circle", "#Circle_list", "Circles");
                createTable(QueryTask, Query, mandal_url, query_con, out_fields);
            function setMapFeatureToExtent(QueryTask, Query, url, condition) {
                var queryTask = new QueryTask(url);
                var query = new Query();
                query.returnGeometry = true;
                query.outFields = ["*"];
                query.outSpatialReference = map.spatialReference;
                query.where = condition;
                queryTask.execute(query, function (results) {
                    console.log(results.features.length)
                    map.setExtent(results.features[0].geometry.getExtent())
RobertScheitlin__GISP
Satyanarayana,
Is the zone_id and circle numeric fields or a strings?
Robert,
Thanks for the reply. Both are integers. the same query is working in arcmap, but not on gisservice.
Have you tried to just execute the query on the rest endpoint page?
sde.sde.GHMC_Circles_pt1.circle = 1 AND sde.sde.GHMC_Circles_pt1.zone_id = 1
