HiI would like to use two info windows, both displaying different results.One will be for the address search results (once the map zoom's into the location)//the info window for the address details after zooming to location on map
function buildAddWindow(addr, pt) {
var replacement = ", ";
var addrTrim = addr.replace(/\|LOCATOR_SEPARATOR\|/g, replacement);
console.log(addrTrim);
var addInfoTemplate = new esri.InfoTemplate(addrTrim);
map.infoWindow.setTitle("Address");
map.infoWindow.setContent("Address : " + addrTrim);
map.infoWindow.resize(250, 175);
map.infoWindow.show(pt, esri.dijit.InfoWindow.ANCHOR_LOWERRIGHT);
The other is for the identify results its quite complex so this is just a section of where it creates the info window: // identify and retrieve layers from the rest endpoint
function setUpIdentify(layers) {
//when user clicks on map, call doIndentify()
//map.graphics.clear();
dojo.connect(map, "onClick", doIdentify);
console.log("Setting up identify");
identifyTask = new esri.tasks.IdentifyTask("http://sccw08ags/ArcGIS/rest/services/APILBSR/MapServer");
identifyParams = new esri.tasks.IdentifyParameters();
//identifyParams.spatialReference = new esri.SpatialReference({ wkid: 27700});
identifyParams.tolerance = 5;
identifyParams.returnGeometry = true;
identifyParams.layerIds = layers;
//console.log(layers);
//identifyParams.layerIds = visible;
identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
//create info window
//var ideninfoTemplate = new esri.InfoTemplate();
map.infoWindow.resize(480, 300);
map.infoWindow.setContent(dijit.byId("tabs").domNode);
map.infoWindow.setTitle("Identify Results");
function doIdentify(evt) {
console.log("Do Identify");
identifyParams.geometry = evt.mapPoint;
identifyParams.mapExtent = map.extent;
var mapLevel = map.getLevel();
if (mapLevel >=7 ) {
identifyTask.execute(identifyParams, function(idResults) { addToMap(idResults, evt); });
}else {
alert("This has returned too many results.\n\nPlease zoom in or search for an address to narrow your selection");
I am having issues when once a user has done an address search and the map has zoomed into the location and shown the address details in the info window. If i then click on a item to run the identify task i get an error relating to the following function:// add results to info window - custom to this application each layer results are manually configured here
function addToMap(idResults, evt) {
layer7results = { displayFieldName: null, features: [] };
layer3results = { displayFieldName: null, features: [] };
layer4results = { displayFieldName: null, features: [] };
layer2results = { displayFieldName: null, features: [] };
layer0results = { displayFieldName: null, features: [] };
layer1results = { displayFieldName: null, features: [] };
for (var i = 0, il = idResults.length; i < il; i++) {
var idResult = idResults;
if (idResult.layerId === 7) {
if (!layer7results.displayFieldName) { layer7results.displayFieldName = idResult.displayFieldName };
layer7results.features.push(idResult.feature);
} else if (idResult.layerId === 3) {
if (!layer3results.displayFieldName) { layer3results.displayFieldName = idResult.displayFieldName };
layer3results.features.push(idResult.feature);
} else if (idResult.layerId === 4) {
if (!layer4results.displayFieldName) { layer4results.displayFieldName = idResult.displayFieldName };
layer4results.features.push(idResult.feature);
} else if (idResult.layerId === 2) {
if (!layer2results.displayFieldName) { layer2results.displayFieldName = idResult.displayFieldName };
layer2results.features.push(idResult.feature);
} else if (idResult.layerId === 0) {
if (!layer0results.displayFieldName) { layer0results.displayFieldName = idResult.displayFieldName };
layer0results.features.push(idResult.feature);
} else if (idResult.layerId === 1) {
if (!layer1results.displayFieldName) { layer1results.displayFieldName = idResult.displayFieldName };
layer1results.features.push(idResult.feature);
dijit.byId("layer7Tab").setContent(layerTabContent(layer7results, "layer7results", evt.mapPoint));
dijit.byId("layer3Tab").setContent(layerTabContent(layer3results, "layer3results", evt.mapPoint));
dijit.byId("layer4Tab").setContent(layerTabContent(layer4results, "layer4results", evt.mapPoint));
dijit.byId("layer2Tab").setContent(layerTabContent(layer2results, "layer2results", evt.mapPoint));
dijit.byId("layer0Tab").setContent(layerTabContent(layer0results, "layer0results", evt.mapPoint));
dijit.byId("layer1Tab").setContent(layerTabContent(layer1results, "layer1results", evt.mapPoint));
map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
I am getting an error that dijit.byId("layer7Tab") is not defined. Any ideas? Thanks
