function transmittingRenderCell(object, value, cell, options){ var greenLight = new Image(); greenLight.src = "images/greenLight.png"; var redLight = new Image(); redLight.src = "images/redLight.png"; var inputDate = new Date(value); return dojo.date.locale.format(inputDate); var currentDateTime = new Date(); //var day = currentDateTime.getDate(); //var month = currentDateTime.getMonth()+1; //var year = currentDateTime.getFullYear(); //var hours = currentDateTime.getHours(); //var minutes = currentDateTime.getMinutes(); //var date = month + "/" + day + "/" + hours + ":" + minutes; if(inputDate = currentDateTime){ return greenLight; } //else{ //return redLight; //} }
Jon,
I tried the formatter with get, and the images are showing, but not correctly. They all show red even though there should be some red and some green. I think this has to do with the fact that the original TimeStamp is in epoch time and I am trying to compare it to the new Date(). Is there a way to format it, then compare the formatted TimeStamp? Or, do I need to create a new column and compare the formatted column to new Date(), then use Column Hider to hide the formatted TimeStamp column so that all that shows is the image? You are helping me with another issue, and the information for this issue is in the jsfiddle for that one. It's the same website.
Again, any help is much appreciated.
columns: [ { label:"Last Seen", field: "lastMod", formatter: function(value){ var timeStamp = new Date(value); var minutesAgo = Math.floor((new Date().getTime() - value) / 60000); if(minutesAgo > 0 && minutesAgo < 1){minutesAgo = 1}; if(minutesAgo > 60){ var hours = minutesAgo / 60; if( hours > 24){ var days = hours / 24; return Math.floor(days) + " Day(s)"; } return Math.floor(hours) + " Hour(s)"; } return minutesAgo + " Minute(s)"; } } ];
//1397236556000 var lastUpdated = 1397236556000; //1397248094113 var rightNow = new Date().getTime(); // var minutesSinceLastUpdate = Math.floor((1397248094113 - 1397236556000) / 60000); // var minutesSinceLastUpdate = Math.floor((rightNow - lastUpdated) / 60000); var minutesSinceLastUpdate = Math.floor((new Date().getTime() - lastUpdated ) / 60000); //minutesSinceLastUpdate is equal to 192 Minutes
Am I correct in assuming that the images are in their own column (a unique cell on each row in the table)?
<!DOCTYPE html> <html> <head> <meta charset="utf-8"> <title>dynamic dgrid columns</title> <link rel="stylesheet" href="https://community.esri.com//ajax.googleapis.com/ajax/libs/dojo/1.9.1/dojo/resources/dojo.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/tundra/tundra.css" /> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dgrid/css/dgrid.css"> <style type="text/css"> body, html{ margin:0; padding:0; height:100%; width:100%; } #grid{ border:0px; width:100%; height:100%; } </style> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <script src="http://js.arcgis.com/3.8/"></script> <script> var data = [{"id":0,"col1":"normal","col2":false,"col3":"new","col4":"But are not followed by two hexadecimal","col5":29.91,"col6":10,"col7":false},{"id":1,"col1":"important","col2":false,"col3":"new","col4":"Because a % sign always indicates","col5":9.33,"col6":-5,"col7":false},{"id":2,"col1":"important","col2":false,"col3":"read","col4":"Signs can be selectively","col5":19.34,"col6":0,"col7":true},{"id":3,"col1":"note","col2":false,"col3":"read","col4":"However the reserved characters","col5":15.63,"col6":0,"col7":true},{"id":4,"col1":"normal","col2":false,"col3":"replied","col4":"It is therefore necessary","col5":24.22,"col6":5.5,"col7":true},{"id":5,"col1":"important","col2":false,"col3":"replied","col4":"To problems of corruption by","col5":9.12,"col6":-3,"col7":true},{"id":6,"col1":"note","col2":false,"col3":"replied","col4":"Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris","col5":12.15,"col6":-4,"col7":false},{"id":7,"col1":"normal","col2":false,"col3":"new","col4":"But are not followed by two hexadecimal","col5":29.91,"col6":10,"col7":false},{"id":8,"col1":"important","col2":false,"col3":"new","col4":"Because a % sign always indicates","col5":9.33,"col6":-5,"col7":false},{"id":9,"col1":"important","col2":false,"col3":"read","col4":"Signs can be selectively","col5":19.34,"col6":0,"col7":true},{"id":10,"col1":"note","col2":false,"col3":"read","col4":"However the reserved characters","col5":15.63,"col6":0,"col7":true},{"id":11,"col1":"normal","col2":false,"col3":"replied","col4":"It is therefore necessary","col5":24.22,"col6":5.5,"col7":true},{"id":12,"col1":"important","col2":false,"col3":"replied","col4":"To problems of corruption by","col5":9.12,"col6":-3,"col7":true},{"id":13,"col1":"note","col2":false,"col3":"replied","col4":"Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris","col5":12.15,"col6":-4,"col7":false},{"id":14,"col1":"normal","col2":false,"col3":"new","col4":"But are not followed by two hexadecimal","col5":29.91,"col6":10,"col7":false},{"id":15,"col1":"important","col2":false,"col3":"new","col4":"Because a % sign always indicates","col5":9.33,"col6":-5,"col7":false},{"id":16,"col1":"important","col2":false,"col3":"read","col4":"Signs can be selectively","col5":19.34,"col6":0,"col7":true},{"id":17,"col1":"note","col2":false,"col3":"read","col4":"However the reserved characters","col5":15.63,"col6":0,"col7":true},{"id":18,"col1":"normal","col2":false,"col3":"replied","col4":"It is therefore necessary","col5":24.22,"col6":5.5,"col7":true},{"id":19,"col1":"important","col2":false,"col3":"replied","col4":"To problems of corruption by","col5":9.12,"col6":-3,"col7":true},{"id":20,"col1":"note","col2":false,"col3":"replied","col4":"Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris","col5":12.15,"col6":-4,"col7":false},{"id":21,"col1":"normal","col2":false,"col3":"new","col4":"But are not followed by two hexadecimal","col5":29.91,"col6":10,"col7":false}]; require([ "dojo/_base/declare", "dgrid/OnDemandGrid", "dojo/ready", "dojo/store/Memory", ], function(declare, OnDemandGrid, ready, Memory){ ready(function () { var dataStore; var CustomGrid = declare([ OnDemandGrid]); var grid = new CustomGrid({ bufferRows: Infinity, cellNavigation: false, escapeHTMLInData: false, noDataMessage: "NO DATA", loadingMessage: "LOADING", selectionMode: "single", }, "grid"); var columnExample1 = [ { "field": "col1", "label" : "col1" }, { "field": "col2", "label" : "col2" }, { // You can reuse field values to create compound columns "field": "col2", "label" : "SUPER COLUMN", "formatter" : function (value) { return "col1: " +value[0] + " ... col2: " + value[1]; }, "get" : function (obj) { // obj represnts the the whole row... you can access different cells by their field // E.G. obj.col1 or obj.col3 return [obj.col1, obj.col2]; } }, { "field": "col3", "label" : "col3", "formatter" : function (value) { return value; }, "get" : function (obj) { if(obj.col3 === "new"){ return "<div style='width:15px; height:15px; background-color:green;'></div>"; }else if(obj.col3 === "read"){ return "<img src='http://upload.wikimedia.org/wikipedia/commons/5/52/Small_red_circle.png' />"; } return obj.col3; } }, { "field": "col4", "label" : "col4", "formatter" : function (value) { return value; }, "get" : function (obj) { return obj.col4; } } ]; // Set Columns grid.setColumns(columnExample1); // If you use a store... dataStore = new Memory ({"data": data}); grid.set("store", dataStore); grid.startup(); }); }); </script> </head> <body class="tundra"></body> </html>
Jon,
columns: { "id": {"label": "", renderCell: actionRenderCell}, "vehicleid": "Unit ID", "velocity": { "label": "Speed (MPH)", "formatter": dojoNum.format }, "timestamp":{"label":"Last Contact", "formatter":function(value){ var lastMod = new Date(value); var minutesAgo=Math.floor((newDate().getTime()- lastMod)/60000); if(minutesAgo>15){return "<img src='images/redLight'/>";} else{return "img src='images/greenLight'/>";} }} }
Jon,
I tried your solution, bringing in the information i believed would be helpful, but the grid is not populating at all. Here is the code for all the columns for that grid.columns: { "id": {"label": "", renderCell: actionRenderCell}, "vehicleid": "Unit ID", "velocity": { "label": "Speed (MPH)", "formatter": dojoNum.format }, "timestamp":{"label":"Last Contact", "formatter":function(value){ var lastMod = new Date(value); var minutesAgo=Math.floor((newDate().getTime()- lastMod)/60000); if(minutesAgo>15){return "<img src='images/redLight'/>";} else{return "img src='images/greenLight'/>";} }} }
I want the red circle to show up if minutesAgo is greater than 15, otherwise the green circle should show. I believe this is the correct code, but am not sure why it's not populating the grid.
