The size attribute on SimpleMarkerSymbol is not working
1898
01-12-2017 07:05 AM
SethPatrich2
New Contributor II
I am setting the size on a SimpleMarkerSymbol using the 4.2 JavaScript API, but it is not having any effect on the resulting symbols.  I have been assigning the value according to these examples.
In this case, I'm getting the shape of the symbol from an SVG string.
Here is a sample app to replicate the issue:
<!DOCTYPE html>
<html>
<head>
 <title>Resize SimpleMarkerSymbols</title>
 <style>
 html,
 body,
 #viewDiv {
 padding: 0;
 margin: 0;
 height: 100%;
 width: 100%;
 </style>
 <link rel="stylesheet" href="https://js.arcgis.com/4.2/esri/css/main.css">
 <script src="https://js.arcgis.com/4.2/"></script>
 <script>
 require([
 "esri/Map",
 "esri/views/MapView",
 "esri/symbols/SimpleMarkerSymbol",
 "esri/geometry/Point",
 "esri/Graphic",
 "dojo/domReady!"
 ], function (Map, MapView, SimpleMarkerSymbol, Point, Graphic) {
 var map = new Map({
 basemap: 'hybrid'
 var view = new MapView({
 center: [-84.3852995, 33.7678835],
 container: "viewDiv",
 map: map,
 zoom: 13
 //Create SVG Icon
 var iconPath = "M12 2C6.48 2 2 6.48 2 12s4.48 10 10 10 10-4.48 10-10S17.52 2 12 2z";
 var markerSymbol = new SimpleMarkerSymbol(
 path: iconPath,
 color: "#3F51B5",
 outline: {
 color: [255, 255, 255],
 width: 1
 var point = new Point({
 longitude: -84.3852995,
 latitude: 33.7678835
 var pointGraphic = new Graphic({
 geometry: point,
 symbol: markerSymbol
 view.graphics.add(pointGraphic);
 </script>
</head>
<body>
 <div id="viewDiv"></div>
</body>
</html>
RobertScheitlin__GISP
Seth,
   This seems to be a bug in 4.2 as your code works fine in 4.1. You should call esri tech support and report this issue.
TimWitt2
The size property does work, but I think SVG items have a set size that can't be changed within your SimpleMarkerSymobols.
SethPatrich2
New Contributor II
It can according to the Esri sample (this one is on v3.19, so it may only be affecting v4.2):
ArcGIS API for JavaScript Sandbox
You can add this line within the createSymbol method:
markerSymbol.size = "48px";
and it will adjust the size of the SVG graphics.
TimWitt2
I see, so it is wonky with SVGs.
Seth,
