Simple example to add a polygon to a map?
3237
12-07-2015 12:50 PM
JimSirianni
Is there a simple example on how to add a polygon to a map? (Web API)
I'm trying to add a polygon to a map and fill it in.
Currently I have:
<script>
        var map;
        require([
          "esri/map",
          "esri/geometry/Extent",
          "esri/layers/FeatureLayer",
          "esri/symbols/SimpleLineSymbol",
          "esri/symbols/SimpleFillSymbol",
          "esri/symbols/TextSymbol",
          "esri/renderers/SimpleRenderer",
          "esri/geometry/Polygon",
          "esri/layers/GraphicsLayer",
          "esri/layers/LabelClass",
          "dojo/_base/Color",
          "dojo/domReady!"
        ], function(Map, Extent, FeatureLayer, SimpleLineSymbol, SimpleFillSymbol,
          TextSymbol, SimpleRenderer, Polygon, GraphicsLayer, LabelClass, Color) {
            map = new Map("map", {
                showLabels: true, //very important that this must be set to true!
                basemap: "streets",
                center: [-79.746933, 40.446949],
                zoom: 8
            var graphicLayer = new GraphicsLayer();
            var bCounty = new Polygon(loadBCounty());
            map.addLayer(graphicLayer);
            graphicLayer.add(bCounty);
        function loadBCounty()
            return [[-80.395815,40.477370],
          [-80.394242,40.477313],
          [-80.394050,40.477306],
          [-80.362057,40.477539],
          [-80.164173, 40.978097],
          [-80.164226, 40.979473],
          [-80.164877, 40.995214],
          [-80.165292, 41.000474],
          [-80.161159, 41.004532],
          [-80.154676, 41.010891],
          [-80.137160, 41.028076],
          [-80.460466, 40.477488],
          [-80.448980, 40.477701],
          [-80.438175, 40.477783],
          [-80.395815, 40.477370]
</script>
RobertScheitlin__GISP
Jim,
   You are forgetting to create the graphic to add to the GraphicsLayer. You are trying to add the Polygon directly.
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Shapes and Symbols</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css">
  <style>
    html,
    body,
    #map{
      padding: 0;
      margin: 0;
      height: 100%;
  </style>
  <script src="https://js.arcgis.com/3.15/"></script>
  <script>
    var map;
    require([
          "esri/map",
          "esri/graphic",
          "dojo/_base/Color",
          "dojo/domReady!"
        ], function (Map, Graphic, Extent, FeatureLayer, SimpleLineSymbol, SimpleFillSymbol,
            basemap: "streets",
            zoom: 8
          var countyGraphic = new Graphic(bCounty, new SimpleFillSymbol(), {"Name": "Beaver"});
          graphicLayer.add(countyGraphic);
          function loadBCounty() {
           return  [[-80.395815, 40.477370],
                    [-80.394242, 40.477313],
                    [-80.394050, 40.477306],
                    [-80.362057, 40.477539],
                    [-80.395815, 40.477370]];
  </script>
</head>
<body>
  <div id="map"></div>
</body>
</html>
Jim,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #map{
      padding: 0;
      margin: 0;
      height: 100%;
  </style>
  <script>
    var map;
    require([
          "esri/map",
          "esri/graphic",
          "dojo/_base/Color",
          "dojo/domReady!"
            basemap: "streets",
            zoom: 8
  </script>
</head>
<body>
</body>
</html>
JimSirianni
Thank you.  This should help me better understand working with the API's.
williamcarr
Occasional Contributor II
Thanks Robert, this solved one of my issues as well.
