Selecting a single layer
2797
12
02-09-2016 12:46 AM
SaurabhRohilla
Hi
Actually i am making a layer list . I am able to get all layers at one time.I am accessing map service layers.Anyone knows how to get only one  layer at a time?
nita14
Hi Saurabh,
there is no way to set visibility to each layer in ArcGISTiledMapServiceLayer since it is just a static 'snapshot' of your data (just like image). You can only set transparency or visibility to the whole service. See TiledMapServiceLayer | API Reference | ArcGIS API for JavaScript  for reference.
Regards,
Adam
RobertScheitlin__GISP
Saurabh,
   Not sure I understand your question. If you are asking how to set the visibility of a particular layer in a ynamic map service layer then you would use setVisibleLayers method:
ArcGISDynamicMapServiceLayer | API Reference | ArcGIS API for JavaScript | setVisibleLayers
SaurabhRohilla
Robert
Thanks for reply.Actually i am new to GIS ,so can you share sample code for that?
Saurabh,
  Sure here is a sample:
<!DOCTYPE html>
<html>
  <head>
<meta name="description" content="Testing sublayer visibility">
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Create Map and add a dynamic layer</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css"/>
    <style>
      html, body, #mapDiv{
        padding: 0;
        margin: 0;
        height: 100%;
    </style>
    <script src="https://js.arcgis.com/3.15/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/layers/ArcGISDynamicMapServiceLayer"
      ], function (
        Map, ArcGISDynamicMapServiceLayer) {
        map = new Map("mapDiv", {
          basemap: "topo",
          zoom: 10,
          center: [-98.258, 38.236]
        var dynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer");
        map.addLayer(dynamicMapServiceLayer);
        dynamicMapServiceLayer.setVisibleLayers([0,1,3,5]);
    </script>
  </head>
  <body>
    <div id="mapDiv"></div>
  </body>
</html>
SaurabhRohilla
Robert,
Thanks.Its working absolutely fine.But when i used this for my webmapservice its not working.
I am adding layers  with  ArcGISTiledMapServiceLayer .
Reference :
var TiledMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer");
But if i replace  ArcGISDynamicMapServiceLayer with ArcGISTiledMapServiceLayer in the code , the layers are not switchable. So it means that setVisibleLayers method only works with ArcGISDynamicMapServiceLayer.??
nita14
Hi Saurabh,
Regards,
Adam
SaurabhRohilla
Hi Nicinski,
Thanks for your response.It helps me a lot.
SaurabhRohilla
Hi Nicinski,
One more thing .Actually i am facing problem in writing the classes for require.
Refer code:
require([
  "esri/map",
  "esri/dijit/Scalebar",
  "esri/layers/ArcGISDynamicMapServiceLayer",
  "esri/toolbars/navigation",
    "dojo/on",
  "dojo/parser",
  "esri/dijit/OverviewMap",
   "dijit/registry",
  "esri/tasks/QueryTask",
  "esri/tasks/query",
  "esri/symbols/SimpleMarkerSymbol",
  "esri/InfoTemplate",
  "dojo/_base/Color",
  "dijit/Toolbar",
    "dijit/form/Button",
"dijit/layout/BorderContainer",
  "dijit/layout/ContentPane",
  "dojo/Ready"
], function(Map, Scalebar,ArcGISDynamicMapServiceLayer,Navigation, on, parser,OverviewMap, registry, QueryTask, Query, SimpleMarkerSymbol, InfoTemplate, Color)
Can you please tell me the hierarachy of classes, which to write first and which one to last?
SaurabhRohilla
Hi Robert,
Refer code:
require([
  "esri/map",
    "dojo/on",
  "dojo/parser",
   "dijit/registry",
  "esri/tasks/query",
  "dojo/_base/Color",
  "dijit/Toolbar",
  "dojo/Ready"
thejuskambi
Hello Saurabh,
I dont think it matter what order you add a require as long as the require and parameters are in same order. If a module has a dependency on another module, it will get it with its own require.
Thejus
