I'm falling short here and need some help. I need to ensure that 'this.fsTok' gets set at the startup before 'this.createServerSiteScratchLayer()' but it seems that no matter what fsTok is always undefined in the createServerSiteScratchLayer() function.
fsTok: null
startup: function(){
this.fsTok = this.getFStokFromUrl();
this.createServerSideScratchLayer();
getFStokFromUrl: function () {
tok = ""
var gp = new Geoprocessor("gpServiceURL/execute");
var params = { "inSystem": "someInputParamValue"};
gp.execute(params, retTok);
function retTok(results) {
tok = results[0].value;
return tok
createServerSideScratchLayer: function () {
this.serverSideScratchLayer = new FeatureLayer(this.config.applicationFeatureLayer + '?token=' + this.fsTok,
outFields: ["OBJECTID"]
Solved! Go to Solution.
Can you try with this instead
createServerSideScratchLayer(tok)
You can try to debug the code and see if you are receiving the token and also if the function is approachable.
Or alternatively, you can move your code snippet in the response function instead.
getFStokFromUrl: function () { tok = "" var gp = new Geoprocessor("gpServiceURL/execute"); var params = { "inSystem": "someInputParamValue"}; gp.execute(params, retTok); function retTok(results) { tok = results[0].value;
tok
Try this if that helps.
Cheers,
Manish
Hi James Crandall,
The code looks correct, however it depends if your gp service is sync or async and whether the function waits till the response is received back.
Ideally, you can check if the response is received and put the createServerSiteScratchLayer() in the getFStokFromUrl function's response.
fsTok: null startup: function(){ this.fsTok = this.getFStokFromUrl(); }, getFStokFromUrl: function () { tok = "" var gp = new Geoprocessor("gpServiceURL/execute"); var params = { "inSystem": "someInputParamValue"}; gp.execute(params, retTok); function retTok(results) { tok = results[0].value; //
this.fsTok
results[0].value; you can set this if you need to use it again
this.createServerSideScratchLayer(tok);//or pass as parameter to the function } }, createServerSideScratchLayer: function (token) { this.serverSideScratchLayer = new FeatureLayer(this.config.applicationFeatureLayer + '?token=' + token, { outFields: ["OBJECTID"] }); },
Cheers,
Manish
If this answer solved your question or if you found it helpful please mark it accordingly to help others who have the same question.
Thanks Manish,
I followed your approach but getting "this.createServerSideScratchLayer is not a function" error on this line,
tok
Cheers,
Manish
this works, thanks. Now it has uncovered an additional scope issue when I try to access this.serverSideScracthLayer from another function.
It's very difficult to inherit code from another developer that has written so many functions that separate out all of the logic. Plus I'm still not fully understanding scope and accessing/setting variables that can be used later on.
I am glad that worked out for you.
I understand when trying to inherit code from another developer it an always be challenging but I am sure you will find a way out 🙂
Regarding the scope issue, I usually either pass it as a parameter from function to function or create a global class that holds all the variables and reference it throughout the application.
