SAML SSO in Javascript app
1966
05-14-2019 09:20 AM
StefanoTassara
Hi all,
I'm having a hard time figuring out how to achieve a Single Sign On experience from a JS application. Let me explain in detail my situation:
  • Portal for ArcGIS 10.4.1 federated with an ArcGIS Server 10.4.1
  • Identity has been federated:
  • In Portal I have created a group and added some users to that group
  • I created a Tile Layer item based on an ArcGis Server Map Service and I shared it with the above-mentioned group
  • I created a new Javascript application that:
    • Authenticates against the IdentityServer and obtains an access token from that
    • References the ArcGIS Javascript API 4.11 to show a map
    • Adds the Tile Layer item to the map
What I got until now is the ESRI authentication dialog appearing as soon as I load the tile layer.
What I want is to access the Tile Layer using the token that I obtained from the IdentityServer, without the user having to sign in again.
Here is the JS code I use to display the map and the Tile Layer:
    var map = new Map({
        layers: [new TileLayer({url: basemapUrl})]});
    var view = new MapView({
        container: "viewDiv",
        map: map
    esriConfig.portalUrl = 'http://atlhqmvmsdev4.eusc.europa.eu/arcgis';
    var portal = new Portal({ isPortal: true });
    portal.authMode = "auto";
    portal.load().then(function () {
        Layer.fromPortalItem({
            portalItem: {
                id: "1b4c51aa3feb42bba71ae02195e03f75" // ID of the Tile Layer item
        .then(function (layer) {
            map.add(layer);
    mgr.getUser().then(function (user) {
        esriId.registerToken({
            token: user.access_token,
            server: portalUrl
What am I missing? Any hint or clarification is very welcome!
Tags (3)
AsthaDevra1
New Contributor II
Did you get this issue fixed ? I am having the same problem with ESRI Federated Server.
Astha
