I saw this question asked in a different part of the forums and it was never answered. I am having the same issue.
I am trying to use the print widget to print a secure map (per the below example of a secure map). None of our stuff is on-prem, it's all ESRI cloud.
I am using a proxy from GitHub - GitHub - Esri/resource-proxy and all calls work fine - except the print widget when attempting to export a SECURE map. I have ensured my credentials were working correctly.
{"error":{"code":400,"message":"Unable to complete operation.","details":["Error executing tool. Export Web Map Task : Layer \"2016 USA Population Density\": Unable to connect to map server at https://demographics6.arcgis.com/arcgis/rest/services/USA_Demographics_and_Boundaries_2016/MapServer... to execute (Export Web Map).\nFailed to execute (Export Web Map Task)."]}}
Thanks in advance,
T
Unfortunately this is for on prem servers. I don't see this as part of the esri API.
Overview | API Reference | ArcGIS API for JavaScript 4.6
Hey Chris wondered if you had any other thoughts? chrissmith
