I have multiple layers and overlapping features that I want to allow the user to click and get the results in a popup. However I also want to be able to create tabs and charts within that popup, like you can for an infoWindow Info window with chart | ArcGIS API for JavaScript. The problem that I'm having is that if I use the popup instead of infowindow then the tabs don't get built correctly until after resizing the window. So it must be possible to make this work I just haven't figured out what needs to happen when. There must be something that I can trigger so that when the popup opens (or switches to another selection) it looks like it does after the resize.
The tabs and charts are getting built using dojo.
Can you by chance post a jsfiddle demonstrating the issue?
I'll work on it but it might take me a day or two to get it set up.
