Popup actions - Capture Close Event
3551
06-18-2020 12:22 PM
AndrewMurdoch1
Occasional Contributor II
Hey
Is there anyway to capture the close event on the Popup?  It's great I can easily launch the Popup, but I want to know when the user closes it.   Specifically this close button:
Thanks
RobertScheitlin__GISP
Andrew,
   In 3.x you look for the popups hide event
https://developers.arcgis.com/javascript/3/jsapi/popup-amd.html#event-hide
In 4.x
        watchUtils.whenTrue(view.popup,'visible', function(){
          watchUtils.whenFalseOnce(view.popup,'visible', function(){
            console.info('popup has been closed');
Andrew,
In 4.x
AndrewMurdoch1
Thanks! That's exactly what I was looking for
PasiSavolainen
New Contributor II
In 4.25 I get this warning
[esri.core.watchUtils] 🛑 DEPRECATED - Module: esri/core/watchUtils
🛠️ Replacement: esri/core/reactiveUtils
:gear:Version: 4.24
I have tried to use reactiveUtils but without success, the watchUtils example works ok. Here is the example that works and the other that I'm not able to get to work.
//works!
watchUtils.whenTrue(view.popup,'visible', () => {
	watchUtils.whenFalseOnce(view.popup,'visible', () => {
//doesn't work
reactiveUtils.whenOnce(() => view.popup.visible).then(() => {
	reactiveUtils.whenOnce(() => !view.popup.visible).then(() => {
	  console.info('how to get here?');
Made a new question for this problem:
https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/popup-capture-close-event-in-4-2x...
