Polygon drawing with Lambert_72 values doen't match
237
10-12-2019 01:52 AM
SergeDe_Backer
New Contributor III
Hello,
I have a problem which needs an urgent solution (like the most of us I guess ). I live in Belgium which uses the Lambert_72 coords. In a nutshell:
  1. I use an API to get me the correct lambert_72 coords : http://loc.geopunt.be/v2/location?q=van%20benedenlaan%2032%20mechelen
  2. Then I use another API to get me the full geometry of that area (parcel): https://geoservices.informatievlaanderen.be/capakey/api/v1/parcel?type=json&x=157460.95&y=190082.14&...
In the 2nd call I get a nice json return:
   "municipalityCode":"12025",
   "municipalityName":"Mechelen",
   "departmentCode":"12403",
   "departmentName":"MECHELEN  3 AFD",
   "sectionCode":"D",
   "perceelnummer":"0013/00A000",
   "capakey":"12403D0013/00A000",
   "grondnummer":"0013",
   "exponent":"A",
   "macht":"000",
   "bisnummer":"00",
   "adres":[
      "Van Benedenlaan 32, 2800 Mechelen"
   "geometry":{
      "boundingBox":"{\"coordinates\":[[[157417.42369999737,190028.28599999845],[157472.0196999982,190028.28599999845],[157472.0196999982,190096.19099999964],[157417.42369999737,190096.19099999964],[157417.42369999737,190028.28599999845]]],\"type\":\"Polygon\",\"crs\":{\"type\":\"link\",\"properties\":{\"href\":\"http://www.opengis.net/def/crs/EPSG/0/31370\"}}}",
      "center":"{\"coordinates\":[157444.72169999778,190062.23849999905],\"type\":\"Point\",\"crs\":{\"type\":\"link\",\"properties\":{\"href\":\"http://www.opengis.net/def/crs/EPSG/0/31370\"}}}",
      "shape":"{\"coordinates\":[[[157429.70069999993,190033.62999999896],[157432.48480000347,190037.28400000185],[157456.1977000013,190068.42199999839],[157460.03270000219,190073.45600000024],[157472.0196999982,190089.19509999827],[157463.03480000049,190096.19099999964],[157454.14069999754,190084.39409999922],[157453.84179999679,190083.99700000137],[157451.09969999641,190080.36410000175],[157440.74469999969,190066.81210000068],[157420.71779999882,190040.58509999886],[157417.42369999737,190036.27299999818],[157420.22770000249,190033.54309999943],[157425.62669999897,190028.28599999845],[157429.70069999993,190033.62999999896]]],\"type\":\"Polygon\",\"crs\":{\"type\":\"link\",\"properties\":{\"href\":\"http://www.opengis.net/def/crs/EPSG/0/31370\"}}}"
   "result":{
      "succes":true,
      "startTimeStamp":"2019-10-12T08:46:26.8125961+00:00",
      "endTimeStamp":"2019-10-12T08:46:26.8907356+00:00",
      "elapsed":78
In this return I see boundingBox coords, centerCoords and shapeCoords.
Now my goal is to draw a polygon using the shapeCoords (of boundingBox coords). However the values I get are Lambert_72 values which I can't get to work .
I have made a testpage where I can see a point created to test if the drawing works and it does.
But when I do the polygon using the Lambert_72 coords provided to me it won't draw at the location I expect. After some reading I read that the rings should be filled with lon/lat coords which I don't have.
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<title>ArcGIS JavaScript Tutorials: Display point, line, and polygon graphics</title>
<style>
html, body, #viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.12/esri/css/main.css">
<script src="https://js.arcgis.com/4.12/"></script>
<script>
require([
"esri/WebMap",
"esri/views/MapView",
"esri/Graphic",
"esri/geometry/Point",
"esri/symbols/SimpleMarkerSymbol",
"esri/geometry/Polygon",
"esri/symbols/SimpleFillSymbol",
"esri/layers/WMSLayer",
], function (WebMap, MapView,
Graphic, Point, SimpleMarkerSymbol,
Polygon, SimpleFillSymbol
var map = new WebMap({
portalItem: {
var view = new MapView({
container: "viewDiv",
map: map,
center: [4.475, 51.02],
zoom: 5
// Create a point
var point = new Point({
longitude: 4.4750893831806655,
latitude: 51.020886794292629
// Create a symbol for drawing the point
var markerSymbol = new SimpleMarkerSymbol({
color: [0, 0, 0],
outline: {
color: [255, 255, 255],
width: 1
// Create a graphic and add the geometry and symbol to it
var pointGraphic = new Graphic({
geometry: point,
symbol: markerSymbol
view.graphics.add(pointGraphic);
// Create a polygon geometry
//Test coords
var x = 4.4750893831806655
var y = 51.020886794292629
var polygon = new Polygon({
rings: [
[x, y],
[x + 0.001, y + 0.001],
[x + 0.003, y + 0.003],
[x, y]
// Create a symbol for rendering the graphic
var fillSymbol = new SimpleFillSymbol({
color: [227, 139, 79, 0.8],
outline: {
color: [0, 0, 0],
width: 1
// Add the geometry and symbol to a new graphic
var polygonGraphic = new Graphic({
geometry: polygon,
symbol: fillSymbol
// Add the graphic to the view
view.graphics.add(polygonGraphic);
});</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
How can I solve this?
Any help is appreciated.
Kind regards,
Serge
SergeDe_Backer
New Contributor III
Apparantly I used the wrong api to get the right ring coords.
SergeDe_Backer
New Contributor III
Ok..I am a bit closer. I added the spatialReferen like this:
rings: [
[157429.70069999993, 190033.62999999896],
[157432.48480000347, 190037.28400000185],
[157456.1977000013, 190068.42199999839],
[157460.03270000219, 190073.45600000024],
[157472.0196999982, 190089.19509999827],
[157463.03480000049, 190096.19099999964],
[157454.14069999754, 190084.39409999922],
[157453.84179999679, 190083.99700000137],
[157451.09969999641, 190080.36410000175],
[157440.74469999969, 190066.81210000068],
[157420.71779999882, 190040.58509999886],
[157417.42369999737, 190036.27299999818],
[157420.22770000249, 190033.54309999943],
[157425.62669999897, 190028.28599999845],
spatialReference: { wkid: 31370 }
And that seems to work a bit but not completely tho...the drawing is off...It doesn't connect completely to the borders.
Is it the map which is wrong? What could be the cause of this?
ToddMetzler
Occasional Contributor II
Hello,
have you looked for a solution here:
projection | ArcGIS API for JavaScript 4.13
Todd
SergeDe_Backer
New Contributor III
Hi Todd,
Well I am now able to use the Lambert_72 coords by using the spatialReference wkid: 31370.
However I have a small mismatch as you can see on the screenshot.
kind regards
SergeDe_Backer
New Contributor III
