Off Center Zoom
2357
6
12-19-2014 07:42 AM
WesAskew
New Contributor II
I am trying to determine the best way to off center a zoom based on browser window size.  I have a div container nested within my map div on the right side which takes up 20% of the screen.  I would like to off center the map.centerAt() function 20% to the left to compensate for this taken space.  Does anyone have an idea on the best way of going about this?  Any suggestions are greatly appreciated.  Thanks in advance.
HeikoHeijenga
Convert the point you want to center on to a screen point, this will give you the coordinates in pixel space. Then substract/add 0.2*map.width from the X value and convert the point back to map units and use that to center on. Makes sense?
HeikoHeijenga
HeikoHeijenga
You can also skip the unit conversion and use 0.2*map.extent.getWidth()...
WesAskew
New Contributor II
Thanks, worked perfectly for my point features.  Would a similar method be used for polygons?
HeikoHeijenga
to do what? map.centerAt only works with points...
WesAskew
New Contributor II
I would like to off center my polygon features the same way.  Currently I am using :  map.setExtent(polygonFeatureLayer.geometry.getExtent().expand(1.1));  Would I simply do the same for the x coordinate for the polygon and recalculate the extent?
HeikoHeijenga
Yeah, you would do it the same way; loop over all vertices in the polygon and offset the X.
