NIM085352  - When will be this bug fixed?
4065
6
04-10-2013 06:17 AM
MartinRinner
Hello everyone,
IMHO this bug is serious for developing webapps. More complex apps with the ability to switch the layer visibility of sublayers of a mapservice can't be build until this bug isn't solved. As a workaround, you must re-build the whole infowindow, all the things like charting...
http://support.esri.com/en/bugs/nimbus/TklNMDg1MzUy
Regards,
Martin
MartinRinner
Dear staff at Esri,
are the any news?
Martin
RandyKreuziger
Occasional Contributor III
Martin,
  If your site is on maintenance you should call ESRI support and ask if it's been assigned to a tech.  If not, then they're not even working on it at this time.
SubaKrishnan
Hi Martin,
I just checked the status of the bug; it is not yet assigned to a developer.
Suba
AntonSizo
This bug migrated to the Web AppBuilder for ArcGIS. It is quite shame not to address it and move it to the new product.
KellyHutchins
Esri Frequent Contributor
I'm pretty sure this bug has been addressed in ArcGIS Online and the templates. I also ran a quick test using the Web App Builder and it looks fixed there as well. Do you have a test web map that still shows the problem?
JeffJacobson
It looks like the status is now ​Closed: Will Not be Addressed​.
