MultipleDefine error while executing Heat Map tool from ArcGIS javascript API
883
09-04-2018 02:21 AM
DavidGago
i have an app made in js that works with arcgis and it looks like:
require([
"dojo/_base/array",
"esri/geometry/Circle",
"esri/Color",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/PictureMarkerSymbol",
"esri/symbols/SimpleMarkerSymbol",
"esri/renderers/SimpleRenderer",
"esri/renderers/UniqueValueRenderer",
"esri/tasks/StatisticDefinition",
"esri/geometry/geometryEngine",
"esri/graphic",
"dijit/registry",
"esri/tasks/query",
"esri/tasks/QueryTask",
"esri/tasks/RelationshipQuery",
"esri/SpatialReference",
"esri/map",
"esri/lang",
"esri/dijit/InfoWindow",
"esri/InfoTemplate",
"dijit/layout/ContentPane",
"dijit/layout/TabContainer",
"esri/layers/GraphicsLayer",
"esri/layers/FeatureLayer",
"esri/geometry/Point",
"esri/tasks/FeatureSet",
"esri/dijit/BasemapToggle",
"esri/dijit/HomeButton",
"esri/dijit/LayerList",
"esri/dijit/Search",
"dojo/_base/connect",
"dojo/dom-style",
"dojo/dom",
"dojo/on",
"dojo/dom-construct",
"dojo/dom-class",
"dojo/number",
"esri/renderers/HeatmapRenderer",
"dojo/domReady!"
function(
array, Circle, Color, SimpleFillSymbol, SimpleLineSymbol, PictureMarkerSymbol, SimpleMarkerSymbol, SimpleRenderer,
UniqueValueRenderer, StatisticDefinition, geometryEngine, Graphic, registry, Query, QueryTask, RelationshipQuery, SpatialReference,
Map, esriLang, InfoWindow, InfoTemplate, ContentPane, TabContainer, GraphicsLayer, FeatureLayer, Point, FeatureSet,
BasemapToggle, HomeButton, LayerList, Search, connect, domStyle, dom, on, domConstruct, domClass, number, HeatmapRenderer
map = new Map("map", {
basemap: "gray",
center: [-0.4814900, 38.3451700],
zoom: 11
var flay0H = new FeatureLayer(urlFlay0H, {
mode: FeatureLayer.MODE_SNAPSHOT,
visible: false,
outFields: ["*"]
map.addLayer(flay0H);
var HeatM = new HeatmapRenderer({
blurRadius: 4,
maxPixelIntensity: 900,
minPixelIntensity: 9,
field: "Precio"
var heat_btn = document.getElementById("heat_btn");
heat_btn. = click5;
function click5() {
if (flay0H.visible == false) {
flay0H.setRenderer(HeatM);
// flay0H.refresh();
flay0H.setVisibility(true);
} else {
flay0H.setVisibility(false);
When i run the tool sometimes an error occurs and i get this message in the console:
This layer only participate in this process so i dont understand what can fail here. Any ideas?Ty.
KellyHutchins
Esri Frequent Contributor
It looks like you are using a js library called jszip? If so try loading it before you load the jsapi.
  <script src="https://cdnjs.cloudflare.com/ajax/libs/jszip/3.1.5/jszip.min.js"></script>
  <script src="https://js.arcgis.com/4.8"></script>
DavidGago
im not using that js library, my html looks like:
KellyHutchins
Can you put together a reproducible test case? If so can you post it here or email?
DavidGago
Thanks for the reply.
Sorry, here is the test case: https://jsfiddle.net/z05d8w63/6/
The error always occurs after filtering any layer. Click on the  icon of the card and write 03003 in the textbox, and then click on the icon of the flame and the error appears.
