Measurement Window Units Dropdown ZIndex
2826
03-11-2014 08:14 AM
JosephHamilton
[ATTACH=CONFIG]32114[/ATTACH]
I am using KendoUI for HTML5 controls. So far everything has worked great and I have a common look and feel for my app. However, when I try and put the measurement tool inside of a kendo window, the drop down to select the units ZIndex is always behind the control.
If I put the measurement tool in a dojo panel, it does work, but I would like to keep with a consistent feel for my app.
Has anyone else encountered or solved this?
JosephHamilton
I figured it out.
I listen for the click event on the Measurement Unit DropDownButton:
      app.measurement.unit.on("click", function () {
            //Found the class using the page inspector
            //It adds a new div with a new ID for every click
            $(".dijitPopup.dijitMenuPopup").each(function () {
                //KendoUI window zIndex start at 10,000
                $("#" + this.id)[0].style.zIndex=20000;
JosephHamilton
I figured it out.
HaroldBostic
Occasional Contributor II
@3.13 it's
measurementTool._unitDropDown.on('click', function () {
            $('.dijitPopup.dijitMenuPopup').each(function() {
                $('#' + this.id).css('z-index', 2000);
