Load Feature Layer inside webmap in Snapshot mode
3842
8
01-20-2016 09:46 AM
MohamedNabil1
hi,
I have features layer inside a webmap on ArcGIS Online, I want to load this feature layer in Snapshot Mode not in on demand mode.
How can I do this without adding the feature layer again, and losing all its configuration saved in the web map.
Thanks.
RickeyFight
MVP Regular Contributor
Are you using a javascript application or ArcGIS Online​?
MohamedNabil1
Javascript Application
RickeyFight
Try:
  var featureLayer = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/FeatureServer...", {
    mode: FeatureLayer.MODE_ONDEMAND,
    tileWidth: 200,
    tileHeight: 200
https://developers.arcgis.com/javascript/jsapi/featurelayer-amd.html
MohamedNabil1
true, but I am accessing webmap object which include the feature layer, so I don't initialize the feature layer
NiklasKöhn
Hey all,
I know this is an old question, but I'd like to revive the discussion, because I'm having the exact same problem.
Use case: I'm using ArcGIS webappbuilder‌ with the brand new dashboard theme‌ andinfographic widget. The customer wants the "Filter by extent" option to be configurable, and therefore, I need to load the FeatureLayer in Snapshot Mode
The customer wants no programming, which means, no instantiating the FeatureLayer in the code and defining Snapshot mode there. I need to configure this setting in the WebMap or the WebApp, but I didn't find a switch for that.
Can someone help?
Thanks, Nik
NiklasKöhn
Just in case someone's interested: No, it's not possible to do that in a WebMap.
I've solved the issue for my use case by adding the same layer again as an additional data source in the Web AppBuilder. This way, you can use it as input for the Dashboard Infographic Widget and the queries are not restricted to the map extent.
MarkCooper5
Occasional Contributor II
This is exactly the issue I am having. Unfortunately, when I add data that way, you dont appear to be able to filter by selection, unless I am doing something wrong.
Basically, I want to show the data for our whole district, unless someone selects a ward within it. As this doesnt appear possible, I cannot see how the widget can be of any use to me.
NiklasKöhn
That's right. You can configure it one way or the other, but you cannot switch on the fly.
