LayerList JS 4.8 Issues
762
07-09-2018 08:13 AM
Miguel_AngelResendiz_Franco
Hi everyone.
I'm upgrade my app to JS API 4.7 to JS API 4.8, and i have a little issue on layerlist widget.
On 4.7 versión runs normal on toggle visibility layer button, but on 4.8 API versión this button is not showing, i load a mapservice from ArcGIS Server 10.3, can be a compability mapservice problem? I tried with a ArcGIS Server 10.5 and runs normally. Some configuration of map service dor this issue?
I will thank you for your help.
MiranCerkic
New Contributor II
I have exactly the same issue, and would be grateful for any information.
Although for me it doesn't work even for services published on 10.5, but it works with arcgis services like Demographics/USA_Diversity_Index (MapServer)
Best regards,
Miran
by Anonymous User
Not applicable
Hello,
There is a bug being logged for JavaScript 4.8 for this issue.
The number is- BUG-000115608 (Cannot the set ON/OFF visibility of the sublayers from LayerList widget in JavaScript application).
You can track the bug via support.esri.com to see the status of the bug.
Harsh
