JS API 3.29 Print/Export map as an image?
4569
10
08-06-2019 10:48 AM
Claire_Peterson
I have a map that was created using "Selecting Features Using URL Parameters"  where an ID is passed in the URL and the map creates a graphic of the selected feature, zooms to it and hides everything else in the layer (so I can only see the feature that the object ID matches the ID in the URL (along with the basemap and another feature layer). It is a ArcGIS API for JavaScript map built with 3.29 and the map is displayed in a dijit Border Container / Content Pane.
Is there any way to take the final rendered map an convert it into an image to be used elsewhere, say in a PDF along with attributes from that selected feature? The layer that is getting queried is behind credentials so when the page first loads it asks for a log in and then the map renders as it should.
I have tried the screenshot method using html2canvas, canvas.toBlob, Filesaver but the screenshot does not contain anything other than the tiled basemap.
Any help would be greatly appreciated. Thank you.
KenBuja
MVP Esteemed Contributor
Since Ben has answered your initial question, you should click the "Mark Correct" button.
