Hi I have WMS service created from 2 layers. One is a polygon shading and another from a PNG symbol.
When you view it with the javascript viewer you notice that the symbols are semi-transparent. You see this when the symbols overlap the polygon shading. You can see it here
Note there is no transparency set on the layers in the MXD. I tried using this layer on ArcGIS online and there is no transparency effect! see here
When I use this layer in my javascript application I do notice the transparency effect. It should not be there.
Any ideas why this is happening or how to fix? Thanks
Yes it doesn't change anything. I tried 0.2 and it gets very transparent, but 1.0 or anything higher gives the previous result. The most worrying thing is that when I view the layer using the javascript viewer of ArcGIS Server I see the transparency. This tells me it is not an error of my application.
