Is there a way to get past the 1000 feature return limit on a SubLayer?
346
01-16-2019 08:14 PM
deleted-user----ypwdOWHsd
I am trying to return more than 1000 features on a Sublayer of a MapImageLayer. I know that when querying against Feature Layers, you can use the "num" and "start" properties of the Query object to index thorough the return data across queries. However, when I try to use these two properties when querying a SubLayer of a MapImageLayer, I get the error: "Failed to execute query."
Thanks for your help,
Cameron
Noah-Sager
Hi Smith, Cameron, I think you could modify the "Maximum Number of Records Returned by Server:" property of the MapServer in ArcGIS Server Manager. The default is 1000, so if you bump that up, you should be able to return more features.
