The installation guide mentioned the following, do I need ArcGIS Server for this? I have ArcGIS Server 10.1 installed, with the web adapter, but I couldn't find where to configure this. Do you mind explaining how it works and how to configure it? Thanks a lot in advance!
�?�Change the ArcGIS Services Directory "View In JavaScript" URL. Instructions are given in "Configuring the REST API" in the ArcGIS Server REST SDK. On Windows, the location is <Installation Location>\DeveloperKit\Help\REST\index.html. On UNIX and Linux, the location is http://<myserver>:8399/<instance>/sdk/rest/index.html where myserver is your server name and instance is the instance name (jsapi is the default). �?�Find the "JavaScript API" section for either .NET or Java for more information about parameter values. �?�For .NET, the parameters to change in rest.config are <ArcGIS> and <ArcGISCSS>. Replace serverapi.arcgisonline.com with your server domain name. �?�For Java, the parameters to change in rest-config.properties are jsapi.arcgis and jsapi.arcgis.css. Replace serverapi.arcgisonline.com with your server domain name.
