I have usses with my TimeSlider inside a Expand widget
57
Friday
Highlighted
Hi everyone,
I am new at javascript and developing with the Javascript API.
I wanted to add my TimeSlider into a Expand Widget, I successfully did it (I guess) but since my TimeSlider is inside the expand is not working well, so maybe I am missing something or made some mistake. I hope you could help me with this matter.
Thank you so much for your time and your attention.
Excuse me for my broke englsih.
Here is the code:
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>
      Filter features with TimeSlider | Sample | ArcGIS API for JavaScript 4.17
    </title>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.17/esri/themes/dark/main.css"
    <script src="https://js.arcgis.com/4.17/"></script>
    <script>
      require([
        "esri/Map",
        "esri/views/MapView",
        "esri/layers/GeoJSONLayer",
        "esri/widgets/Expand",
        "esri/widgets/TimeSlider",
        "esri/widgets/Legend"
      ], function (
        Map,
        MapView,
        GeoJSONLayer,
        Expand,
        TimeSlider,
        Legend) {
        let layerViewAlertas;
        let layerAlertas = new GeoJSONLayer({
          url:
            "https://raw.githubusercontent.com/Carlos29Blanco/Carlos29Blanco/develop/alertasNormal.geojson",
          copyright: "Influenza Aviar",
          title: "Influenza-Aviar",
          // set the CSVLayer's timeInfo based on the date field
          timeInfo: {
            startField: "startDate", // name of the date field
            interval: {
              // set time interval to one day
              unit: "days",
              value: 7
        let map = new Map({
          basemap: "dark-gray-vector",
          layers: [layerAlertas]
        var view = new MapView({
          map: map,
          container: "viewDiv",
          zoom: 3.6,
          center: [30.68, 48.68]
        // create a new time slider widget
        // set other properties when the layer view is loaded
        // by default timeSlider.mode is "time-window" - shows
        // data falls within time range
        let timeSliderAlertas = new TimeSlider({
          container: document.createElement("div"),
          playRate: 50,
         /*  mode: "cumulative-from-end", */
          stops: {
            interval: {
              value: 7,
              unit: "days",
       // view.ui.add(timeSliderAlertas, "top-left");
        // wait till the layer view is loaded
        view.whenLayerView(layerAlertas).then(function (lv) {
          layerViewAlertas = lv;
          // start time of the time slider
          let start = new Date();
          start.setMonth(start.getMonth()-3);
          // set time slider's full extent to
          // until end date of layer's fullTimeExtent
          timeSliderAlertas.fullTimeExtent = {
            start: start,
            end: new Date()
          // We will be showing alerts with one day interval
          // when the app is loaded we will show alerts that
          // happened between
          let end = new Date();
          // end of current time extent for time slider
          // showing alerts with one day interval
         /*  date.setDate( date.getDate() + 7) */
          start.setDate(start.getDate() + 82);
          // Values property is set so that timeslider
          // widget show the first day. We are setting
          // the thumbs positions.
          timeSliderAlertas.values = [start, end];
        // watch for time slider timeExtent change
        timeSliderAlertas.watch("timeExtent", function () {
          // only show alerts happened up until the end of
          // timeSlider's current time extent.
          layerAlertas.definitionExpression =
            "startDate <= " + timeSliderAlertas.timeExtent.end.getTime();
          // now gray out alerts that happened before the time slider's current
          // timeExtent... leaving footprint of alerts that already happened
          layerViewAlertas.effect = {
            filter: {
              timeExtent: timeSliderAlertas.timeExtent,
              geometry: view.extent
            excludedEffect: "grayscale(40%) opacity(20%)"
        // add a legend for the alerts layer
        let legendExpand = new Expand({
          collapsedIconClass: "esri-icon-collapse",
          expandIconClass: "esri-icon-expand",
          expandTooltip: "Legend",
          view: view,
          content: new Legend({
            view: view
          expanded: false
        view.ui.add(legendExpand, "top-left");
        let timeSliderDropExpand = new Expand({
          expandTooltip: "TimeSlider alertas",
          view: view,
          content: timeSliderAlertas,
          expanded: true
        view.ui.add(timeSliderDropExpand, "top-right");
        expand.content = timeSlider.container
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
Reply
Highlighted
Hi - thank you for sharing the video! One way to fix this would be to set the expand content to the container of the TimeSlider, instead of the TimeSlider itself, like this:
   view: view,
   content: timeSliderAlertas.container,
   expanded: true
Hope this helps!
Highlighted
What issues are you seeing with the TimeSlider inside the Expand widget? I tried out your code and the TimeSlider seems to be appearing properly - but your playRate is very fast so the TimeSlider will speed through its animation once your press play.
Can you be a little more specific about the issue you are seeing?
Anne
Highlighted
Thank you for your answer, I really appreciate it. Excuse me I really don't know how to explain it in English, I did a video instead. It is seem eveytime I move the slider dot this one goes wierd and force me to go back to the start of the slider.
Thank you in advance for your time.
Reply
Highlighted
   view: view,
   expanded: true
Hope this helps!
Highlighted
The Time Slider works perfectly with your suggestion, thank you so much for you help and time!!! 🙏
Reply
