how to use java connecting to arcsde 10.1( base oracle 11.2g)
6576
15
12-17-2012 02:28 AM
zhangyx
i install oracle 11.2g, then use arcgis gp tool create arcsde geodatabase on oracle 11.2g.    how can i use java to connect to arcsde.
how can i write the fallowing code ?
SeConnection connection = null;
connection = new SeConnection(server, instance, database, user, password);
LeoDonahue
ArcObjects Java API is still in play for connecting to your database.  You just need the undocumented correct combination of connection propertyset properties.
I assume you have the correct version of ArcObjects libraries for doing this.  It seems logical that I could not use an ArcObjects 9.3 installation to connect to a newer version of SDE.
Notice the change in SERVERINSTANCE to INSTANCE... that one threw us for a few days.  Found help in the forums.
You can adapt this to Oracle... yes?
    private static void connectToSQLServer(){
        try {
            IPropertySet propertySet = new PropertySet();
            propertySet.setProperty("SERVER", "server name");
            propertySet.setProperty("SERVERINSTANCE", "server instance name");
            propertySet.setProperty("DATABASE", "database name");
            propertySet.setProperty("DBCLIENT", "SQLServer");
            propertySet.setProperty("USER", "sql server user name");
            propertySet.setProperty("PASSWORD", "your password");
            //propertySet.setProperty("AUTHENTICATION_MODE", "DBMS");  // Optional.  DBMS is default
            //propertySet.setProperty("AUTHENTICATION_MODE", "OSA");   // Required if using operating sytem authentication
            IWorkspaceFactory workspaceFactory = new SqlWorkspaceFactory();
            IWorkspace workspace = new Workspace(workspaceFactory.open(propertySet, 0));
            IEnumDatasetName dsFeatureClassNames = workspace.getDatasetNames(esriDatasetType.esriDTAny);
            IDatasetName fcName = dsFeatureClassNames.next();
            while (fcName != null){
                System.out.println(fcName.getName());
        } catch (AutomationException e) {
            e.printStackTrace();
        } catch (IOException e) {
Connecting to SDE would be:
            // Create a propertySet that contains the connection information to ArcSDE
            //  In ArcCatalog, the first three values are: server, service, database in the connection properties of the sde connection.
            propertySet.setProperty("INSTANCE", "sde:sqlserver:server name");
            propertySet.setProperty("USER", "user name");
            propertySet.setProperty("PASSWORD", "user password");
            propertySet.setProperty("VERSION", "sde.DEFAULT");  // or whatever you call your version
            // Create a SdeWorkspaceFactory and open it
            IWorkspaceFactory sdeworkspaceFactory = new SdeWorkspaceFactory();
            IWorkspace workspace = new Workspace(sdeworkspaceFactory.open(propertySet, 0));
VinceAngelo
Esri Esteemed Contributor
While this is true, installing ArcEngine and the ArcObjects SDK on a Linux box
might be a bit ungainly for what is probably a simple SQL statement.
- V
LeoDonahue
yeah probably.  OP never said they wanted to do something easy after making the connection.
MubasharAhmad1
I am trying to connect via direct connection to PostgreSQL spatial db. Java API version is 10.2 postgre 9.6 jdk 6. It successfully connects to database but when I call conn.getLayers() it says "Error getting layers" arcsde error -37 desc: DBMS TABLE DOES NOT EXIST. I dont know which table it is unable to find.
VinceAngelo
PostgreSQL 9.6 is not supported by geodatabases yet, so it can't have an Enterprise geodatabase, so ALL of the geodatabase tables are missing.
- V
santhoshT
