How to use AreaMeasurement2DViewModel
731
01-17-2021 06:05 AM
putra_
Hi i tried to get value for area from area measurment, i am using AreaMeasurement2DViewModel but somehow when i tried to access the value it error it says Cannot read property 'area' of null, i dont know if i am correct using the code, this is my code
<script>
      require([
        "esri/views/MapView",
        "esri/WebMap",
        "esri/widgets/DistanceMeasurement2D",
        "esri/widgets/AreaMeasurement2D",
        "esri/widgets/AreaMeasurement2D/AreaMeasurement2DViewModel",
      ], function (
        MapView,
        WebMap,
        DistanceMeasurement2D,
        AreaMeasurement2D,
        // load a webmap
        const webmap = new WebMap({
          portalItem: {
        // create the map view
        const view = new MapView({
          container: "viewDiv",
          map: webmap,
        var measurementWidget = new AreaMeasurement2D({
          view: view,
        view.ui.add(measurementWidget"top-right");
        // Raw measurements (in meters) can be accessed from this property
       measurementWidget.watch("viewModel.measurement", function(measurement) {
       console.log( "Area: ", measurement.area);
</script>
anyone can help me with this? thank you
AndrewVitale
It looks like the `viewModel.measurement` property gets set to `null` by the widget when you first click the "New measurement" button. Since you're watching the property for ALL changes, the null gets passed into your event handler.
You can simply check if the property is "truthy" before trying to access the properties by guarding your code in an if statement. This is a common pattern, and it's useful outside of the JS API.
Here's a working sample:
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>Esri Playground</title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.18/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.18/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require([
        "esri/WebMap",
      ], function (
        MapView,
        WebMap,
        AreaMeasurement2D,
        // load a webmap
          portalItem: {
          map: webmap,
          view: view,
        view.ui.add(measurementWidget, "top-right");
          function (measurement) {
            console.log({ measurement });
            if (measurement) {
              console.log("Area: ", measurement.area);
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
AndrewVitale
<!DOCTYPE html>
<html>
  <head>
    <meta
      name="viewport"
    <link
      rel="stylesheet"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require([
        "esri/WebMap",
      ], function (
        MapView,
        WebMap,
        AreaMeasurement2D,
        // load a webmap
          portalItem: {
          map: webmap,
          view: view,
            if (measurement) {
    </script>
  </head>
  <body>
  </body>
</html>
putra_
Hi AndreVitale thanks this really is helpful,
i just realize the property gets set to `null` when you first click and because of that i cannot do the measurment, and i using try catch for that
this is my code
try {
} catch (err) {
console.log(0);
