How to take screenshot in Javascript for arcgis basemap with layers
9167
20
03-16-2018 01:09 PM
VenkataDunaka
Hi All,
How to capture the screenshot of map( basemap with additional layers) using Javascript?
Can anyone help on this? Thanks!
RobertScheitlin__GISP
Venkata,
   One of the best ways is to use the esri PrintTask to do this and request Map_Only as the layout.
Example code snippet:
        var oWid = map.width;
        var oHgt = map.height;
        var printTask = new PrintTask('.../rest/services/ExportWebMap/GPServer/Export_Web_Map');
        var template = new PrintTemplate();
        this.imgHeight = (740/oWid) * oHgt;
        template.exportOptions = {
          width: 1542,
          height: (1542/oWid) * oHgt,
          dpi: 200
        template.format = "jpg";
        template.layout = "MAP_ONLY";
        template.preserveScale = false;
        template.showAttribution = false;
        var params = new PrintParameters();
        params.map = this.map;
        params.template = template;
        printTask.execute(params, lang.hitch(this, this.printResult));
      function printResult(rsltURL){
        var mapImg = domConstruct.toDom('<img src="'+rsltURL.url+'" border="0" style="width:740px;height:'+this.imgHeight+'px;"/>');
        domConstruct.place(mapImg, dom.byId('mapImgDiv'), 'replace');
Noah-Sager
As Robert said, the PrintTask is a great solution. I would also recommend the Print Widget if you don't need as fine-grained control. Here are some helpful links:
API Reference: Print Widget | API Reference | ArcGIS API for JavaScript 4.6
API Reference: PrintTask | API Reference | ArcGIS API for JavaScript 4.6
Sample app: Print Widget Sample | ArcGIS API for JavaScript 4.6
-Noah
Juan_ManuelAngel_Cuartas
New Contributor II
Robert one question. this part of the code, return the result to the window i want for example if a want to show in a altert window ?
Juan,
   What is returned is an image url so anything you can do with a image url is what you are limited to. I don't think I have ever tried to put an image in an alert. As far as I know an Alert can only take a string.
New Contributor II
Thank you robert, i refer an alert like a new window  to put an example, thank you !
VenkataSrikanth_Dasari
You can also use/download custom widget named Screenshot widget from the custom widgets list..
ArcGIS Web Application
And you have to use the latest version html2Canvas.js and html2Canvas.svg.js files..
Cheers,
Srikanth Dasari
VenkataDunaka
Hi Srikanth, Thanks for your reply.
I have used html2canvas js to take the screenshot. But I am getting top layer details in the image. Not getting base layer image.
Used code:
document.getElementById("btnSave").addEventListener("click", printToFile);
//Creating dynamic link that automatically click
function downloadURI(uri, name) {
var link = document.createElement("a");
link.download = name;
link.href = uri;
link.click();
function printToFile() {
html2canvas(document.getElementById('panel-container')).then(
function (canvas) {
var myImage = canvas.toDataURL("image/png");
downloadURI("data:" + myImage, "yourImage.png");
html2canvas(document.getElementById('sceneDiv')).then(
function (canvas) {
You have to download the html2canvas.js and html2canvas.svg.js 0.5.0 version files
You can attach the source code here so that I would like to take a look...
FlavieMORAUX1
Hello srikanth dasari venkata‌,
I try to do the same thing but i have a problem. Generated image is almost empty, i have only buttons +/- and copyright, but nothing about content map.
Screen
I follow your advice, that is use 0.5.0 version... I also try to use last version but :
- there is always no map content.
- it does not work with IE 11.
Here is my code, do you see something wrong ?
Thanks a lot
Flavie
<!DOCTYPE html>
<html>
  <head>
    <title>Test screen shot</title>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <link rel="stylesheet" href="https://js.arcgis.com/3.23/esri/css/esri.css">
    <style>
      #tools {
        top: 20px;
        color: #444;
        height: auto;
        font-family: arial;
        right: 20px;
        margin: 5px;
        padding: 10px;
        position: absolute;
        width: 115px;
        z-index: 40;
        border: solid 2px #666;
        border-radius: 4px;
        background-color: #fff;
      html, body, #mapDiv {
        padding:0;
        margin:0;
        height:100%;
      button {
        display: block;
      #mapDiv{
        height: 250px;
    </style>
    <script type="text/javascript" src="html2canvas.js"></script>
    <script src="https://js.arcgis.com/3.23/"></script>
    <script>
      var map;
      require([
        "esri/map", "esri/layers/ArcGISDynamicMapServiceLayer",
        "dojo/dom", "dojo/on", "dojo/domReady!"
      ], function(
        Map, ArcGISDynamicMapServiceLayer,
        dom, on
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-25.312, 34.307],
          zoom: 3
        map.on("load", init);
        var demographicsLayer = new ArcGISDynamicMapServiceLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer");
        map.addLayer(demographicsLayer);
        function init() {
          on(dom.byId("screenShotTool"), "click", function(evt) {
            screenShot();
        function screenShot(){
            html2canvas(document.getElementById('mapDiv')).then(function(canvas){
                document.body.appendChild(canvas);
    </script>
  </head>
  <body>
    <div id="tools">
      <button id="screenShotTool">Screen shot</button>
    </div>
    <div id="mapDiv"></div>
  </body>
</html>
