How to refresh map coordinates if browser window adds scrollbars?
4687
02-12-2015 12:16 PM
ChrisDunlop
New Contributor II
Hello.  I'm working on a simple app that lets the user click on the map to select a polygon and then the attribute information is presented in a results area.  My map is  on the right hand side of the screen (position = fixed).  The results panel is on the left hand side.
When the attribute results get populated, they sometimes extend beyond the screen bottom.  When this happens, the browser window creates a vertical scrollbar, and I can scroll down and see all the attributes (the map stays fixed on the right hand side of the screen).
The problem is, the map isn't aware of the addition of the scrollbar, or if I've scrolled down.  If I then click another point on the map, the coordinates are offset by the scrollbar width, and by the amount I've scrolled down.  So the wrong polygon gets selected.
I'm sure others have run into this.  Is there are easy way to fix this?
Chris
TimWitt2
Chris,
this might to the trick? Map | API Reference | ArcGIS API for JavaScript
map.reposition();
Tim
TimWitt2
Hey Chris,
Can you post your code or a fiddle? That might help!
Tim
ChrisDunlop
New Contributor II
Sorry, here's a stripped down example.  Look at the screenPoint coordinates - the upper left of the map is 0,0.
Then, click the Add Attributes button.  The screenPoint coordinates get shifted about -11 pixels.
Try scrolling down.  You'll see the screenPoint Y coordinates get messed up.
If you resize the browser window the coordinates gets reset.
Chris
<!DOCTYPE html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
<script src="https://js.arcgis.com/3.11/"></script>
<link rel="stylesheet" href="https://js.arcgis.com/3.8/js/esri/css/esri.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css">
<style>
#map
position: fixed;
margin: 0px;
padding: 0px;
top: 10px;
right: 10px;
height: calc(100% - 20px);
width: calc(49% - 20px);
border: 2px solid #BBBBBB;
border-style: solid;
#attributeContainer
position: absolute;
left: 5px;
top:10px;
display: block;
padding:10px;
    width:calc(49% - 20px);
border: 1px solid #BBBBBB;
background:#dbebf7;
z-index: 60;
</style>
<script>
function addAttributes() {
theTxt=""
for (i=0; i<1000; i++) {
  theTxt=theTxt+"yada yada yada "
document.getElementById("attributes").innerHTML=theTxt
require([
    "dojo/parser",
"dojo/dom",
"dojo/on",
    "esri/config",
"esri/map",
"esri/geometry/Extent",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/layers/ArcGISTiledMapServiceLayer",
    "dojo/domReady!"
], function(
  parser,
  dom,
  on,
  esriConfig,
  Map,
  Extent,
  ArcGISDynamicMapServiceLayer,
  // create layout dijits
        parser.parse();
        // specify proxy for request with URL lengths > 2k characters
        //esriConfig.defaults.io.proxyUrl = "../proxy/EsriProxyFile";
  esriConfig.defaults.map.basemaps.OCBasemap = {
  baseMapLayers: [
  { url: "https://webmaps.orcity.org/arcgis/rest/services/Basemap/MapServer" }
   title: "OCBasemap"
  var imageParameters=new esri.layers.ImageParameters()
  imageParameters.format="png32"
        map = new Map("map",{
   zoom: 1,
   scaleSlider: "small",
   basemap: "OCBasemap",
  var cityLimits = new ArcGISDynamicMapServiceLayer("https://webmaps.orcity.org/arcgis/rest/services/CityLimits/MapServer",{"imageParameters":imageParame...});
  map.addLayer(cityLimits);
  map.on("load", mapSetup);
  function mapSetup() {
   map.showZoomSlider();
   map.enableScrollWheelZoom();
   map.enableRubberBandZoom()
   map.on("mouse-move", showCoordinates);
   map.on("mouse-drag", showCoordinates);
  map.setMapCursor("pointer")
  function showCoordinates(e)
   sp=e.screenPoint
   mp=e.mapPoint
   dom.byId("info").innerHTML = "mapPoint="+mp.x.toFixed(3) + ", " + mp.y.toFixed(3) + "   screenPoint=" + sp.x.toFixed(3) + ", " + sp.y.toFixed(3);
</script>
</head>
<body class="claro">
<div id="attributeContainer">
<div id="attributes">
  <button onclick="addAttributes()">Add Attributes</button>
</div>
</div>
<div data-dojo-type="dijit.layout.BorderContainer"
    data-dojo-props="design:'headline',gutters:false"
    style="width: 100%; height: 100%; margin: 0;">
    <div id="map" class="map"
        data-dojo-type="dijit.layout.ContentPane"
        data-dojo-props="region:'center'"
     style="overflow:hidden;">
  <div id="info" style="position:absolute; left:5px; bottom:5px; color:#000; z-index:50;"></div>
</div>
</div>
</body>
</html>
TimWitt2
Chris,
map.reposition();
Tim
ChrisDunlop
New Contributor II
Thanks Tim!  I added map.resposition() after my code that generates the attribute list, and also in a JQuery (window).scroll function.  That seems to catch everything.
Chris
OwenEarley
Occasional Contributor III
You could use CSS rules to prevent the window scrollbar from appearing at all. Set a height value to the attributeContainer div and then only scroll it.
#attributeContainer
    /* other styles... */
    overflow-y: scroll;
    height: calc(100% - 38px);
See this working example.
