how to get desired map through query
2281
23
07-10-2017 03:32 AM
FaryalSafdar
is there any way to get a soil map through query. i have populate area in comobox . now i want to populate combobox with the soil map of the selected area. as my soil has legend of different soil. i.e category option of Arcgis .
esriRequest({
url: "http://localhost:6080/arcgis/rest/services/....../query?where=Area_Name ='" + id.toString() + "'&outFields=Soil&returnGeometry=false&orderByFields=Soil&returnDistinctValues=true&f=json",
content:{
f:'json'
handleAs:'json',
callbackParamName:'callback',
timeout:15000
now the problem is as it has three soil types so combox populate three name and does not display geometry. i want to display whole soil map of the selected area
Tags (1)
RobertScheitlin__GISP
Faryal,
   Your question is pretty confusing. Probably because your workflow is not very clear. If you want to limit a map service or service layer to only show features that qualify based on a query then you set the layers setdefinitionexpression.
FaryalSafdar
my problem is forexample when in arcgis when we select feature through attributes we use dinstict values it select all values of same name. i want to do this here. i have feature layer which categrorized as mention in the picture. i have added a column map and it has same value like soil map. when i select feature through attributes it has selected all features. but when i did this with arcgis query it returns all values of same name.
Faryal,
   Here is a complete sample that shows how to populate dojo combobox with unique values from a query and once selected it does a second query for unique counties from the selected state and on each choice the only drawn graphic is that one the user selects.
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <title>Drop Down Test</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.21/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.21/dojo/resources/dojo.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.21/esri/css/esri.css">
  <script src="http://js.arcgis.com/3.21/"></script>
  <style>
    html,
    body,
    #mainWindow {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      background-color: #FFF;
      overflow: hidden;
      font-family: "Trebuchet MS";
    #header {
      height: 3%;
      overflow: auto;
  </style>
  <script>
    var map;
    require([
      "esri/map",
      "dojo/on",
      "esri/tasks/query",
      "esri/layers/FeatureLayer",
      "dojo/store/Memory",
      "dojo/_base/array",
      "dojo/_base/lang",
      "esri/request",
      "dojo/json",
      "dojo/parser",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dijit/form/Button",
      "dijit/form/ComboBox",
      "dojo/domReady!"
    ], function(
      Map, on, Query, FeatureLayer, Memory, array, lang, esriRequest, json, parser
      parser.parse();
      map = new Map("map", {
        basemap: "topo",
        center: [-98.1883, 37.0868],
        zoom: 5
      esriRequest({
        url: 'http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3/query?where=1%3D1&outF...',
        content:{
          f:'json'
        handleAs:'json',
        timeout:15000
      }).then(lang.hitch(this,function(response){
        var store2 = new Memory({data:[]});
        dijit.byId("stateSelect").set('store',store2);
        var data = array.map(response.features,lang.hitch(this,function(feat, index){
          var name = feat.attributes.STATE_NAME;
          var value = feat.attributes.STATE_NAME;
          var dataItem = {
            value:value
          return dataItem;
        store2 = new Memory({data:data});
      var States = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3", {
        mode: FeatureLayer.MODE_SELECTION,
        outFields: ["*"]
      var Counties = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2", {
        outFields: ["*"]
      map.addLayers([States,Counties]);
      app = {
        zoomRow: function(id, which){
          States.clearSelection();
          Counties.clearSelection();
          var query = new Query();
          var thePoly, theExtent;
          if(which == "State"){
            query.where = "STATE_NAME='" + (id).toString() + "'";
            console.info(query.where);
            query.returnGeometry = true;
            States.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (features) {
              thePoly = features[0].geometry;
              theExtent = thePoly.getExtent().expand(2); //Zoom out slightly from the polygon's extent
              map.setExtent(theExtent);
            esriRequest({
              url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2/query?where=STATE_NAME...'" + id.toString() + "'&outFields=NAME&returnGeometry=false&orderByFields=NAME&returnDistinctValues=true&f=json",
              content:{
                f:'json'
              handleAs:'json',
              timeout:15000
              dijit.byId("countySelect").set('store',store2);
                var name = feat.attributes.NAME;
                var dataItem = {
                return dataItem;
              document.getElementById('countySelect').value = "Select County";
          }else if(which == "County"){
            var county = (id).toString();
            county = county.replace(" County", "");
            query.where = "NAME='" + county + "'";
            Counties.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (features) {
  </script>
</head>
<body class="claro">
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="padding:0px;margin:0px;">
    <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="overflow:hidden;border:none;border-bottom: 3px solid #CC9900;font-family: Windows;font-size:14pt; color: #FFFFFF;background: #000000; "> Select a State/County and zoom to it on the map:
      <input id="stateSelect" data-dojo-type="dijit/form/ComboBox" value="Select State" onchange="app.zoomRow(document.getElementById('stateSelect').value, 'State');" data-dojo-props="maxHeight: 200" />
      <input id="countySelect" data-dojo-type="dijit/form/ComboBox" value="Select County" onchange="app.zoomRow(document.getElementById('countySelect').value, 'County');" />
      <input type="hidden" name="stateabbr" id="stateabbr" />
    </div>
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width:100%;height:95%;border:none;padding:0px;margin:0px;"></div>
  </div>
</body>
</html>
FaryalSafdar
Thanks Robert for your response. here is my code
esriRequest({
url: "http://localhost:6080/arcgis/rest/services/........./query?where=R_Name ='" + id.toString() + "'&outFields=STE&returnGeometry=false&orderByFields=Soil&returnDistinctValues= true&f=json",
content:{
f:'json'
handleAs:'json',
timeout:15000
dijit.byId("RSoil").set('store',store2);
var name = feat.attributes.Soil;
var dataItem = {
return dataItem;
document.getElementById('RSoil').value = "Soil";
else if(which == "RS"){
var rs = (id).toString();
rs = rs.replace("RS", "");
query.where = "Soil='" + rs + "'";
S_layer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (features) {
if(features[0]){
theExtent = thePoly.getExtent().expand(1.8); //Zoom out slightly from the polygon's extent
FaryalSafdar
the query result is like the image. although i have used distinct values = true . but it returns all values. kindly guide me how to solve this problem. it should return only one value.
Faryal,
  Provide your complete code you are using for further assistance.
FaryalSafdar
i have provided my code . kindly review it.
Faryal,
   What version of ArcGIS Server are you using? Why do you have outFields=STE when you are only seeming to use the Soil field?
FaryalSafdar
i am using Arcserver 10.2. i have mistakenly write STE it is Soil.
