How do I get my layer checkboxes to update layer visibility?
6210
22
05-01-2015 11:37 AM
ChrisSergent
Regular Contributor III
I am trying to use this sample to toggle layers: Toggle layer visibility | ArcGIS API for JavaScript  but I receive this error message:
TypeError: Cannot read property 'on' of null {stack: (...), message: "Cannot read property 'on' of null"}
  1. message: "Cannot read property 'on' of null"
  2. stack: (...)
  3. get stack: function () { [native code] }
  4. set stack: function () { [native code] }
  5. __proto__: Error
"in domReady callback"
"TypeError: Cannot read property 'on' of null
and here is my code:
var visibleLayerIds = [];
    on(dom.byId("lyrSigns"), "change", updateLayerVisibility);
    on(dom.byId("lyrSupports"), "change", updateLayerVisibility);
    function updateLayerVisibility() {
        var inputs = query(".list_item");
        var inputCount = inputs.length;
        for (var i = 0; i < inputCount; i++) {
            if (inputs.checked) {
                visibleLayerIds.push(inputs.value);
        if (visibleLayerIds.length === 0) {
            visibleLayerIds.push(-1);
        layer.setVisibleLayers(visibleLayerIds);
And here is my project on github: csergent45/streetSigns · GitHub
StevenGraf1
Occasional Contributor III
Ignore the <span> </span>....It put that in there because I copied my original post.
ChrisSergent
I modified the code as follows:
var checkBox = new CheckBox({
        value: "agreed",
        checked: false,
        onChange: function (b) {
            if (b == true) {
                app.map.addLayer("signLayerUrl");
            } else {
                app.map.removeLayer("signLayerUrl");
    }, "lyrSigns").startup();
And I get the following error: Uncaught lang.hitch: scope["onLoad"] is null (scope="[object Window]")
StevenGraf1
Add in the following module dojo/_base/lang — The Dojo Toolkit - Reference Guide  and see if that corrects the error.
